2117.5
2117.5
    CONTA-CLIP
    PARTITION PLATE
2117.5 数据手册
Data sheet 2117.5 TW 35 BU Partition plate, Width: 1.5 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2117.5 Article name TW 35 BU GTIN (EAN) 4044211049362 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 9.2 g Weight per piece (including packaging) 9.26 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2117.2 Product description Partition plate Creation date 16.12.2023 21:18:32 Subject to technical changes 1 Data sheet 2117.5 TW 35 BU Technical data Dimensions Length 74.6 mm Width 1.5 mm Min. thickness 1.5 mm Height 79.9 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 21:18:32 No Subject to technical changes 2 Data sheet 2117.5 TW 35 BU Media Creation date 16.12.2023 21:18:32 Subject to technical changes 3 Data sheet 2117.5 TW 35 BU Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1163.2 RK 35/Z BG 4044211023737 20 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1494.2 RK 35/IS BG 4044211045272 20 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1052.2 RK 35 BG 4044211011000 20 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 35 mm², Width: 16 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1495.2 RK 35/Z/IS BG 4044211045296 20 Creation date 16.12.2023 21:18:32 Subject to technical changes 4
2117.5 价格&库存
很抱歉,暂时无法提供与“2117.5”相匹配的价格&库存,您可以联系我们找货
