2135.2
    CONTA-CLIP
    END HOLDER
2135.2 数据手册
Data sheet 2135.2 EH 1 BG End support, Mounting type: Mounting surface, Width: 7 mm, Colour: Beige Business data Article number 2135.2 Article name EH 1 BG GTIN (EAN) 4044211049546 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.4 g Weight per piece (including packaging) 2.41 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2135.2 Product description End support Creation date 21.01.2024 06:51:04 Subject to technical changes 1 Data sheet 2135.2 EH 1 BG Technical data Dimensions Length 27 mm Width 7 mm Terminal width 7.00 mm Height 26 mm Hole diameter 3.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Environmental Product Compliance REACH Candidate Substance Note Creation date 21.01.2024 06:51:04 No Subject to technical changes 2 Data sheet 2135.2 EH 1 BG Media Creation date 21.01.2024 06:51:04 Subject to technical changes 3 Data sheet 2135.2 EH 1 BG Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1018.2 RKB 4 BG 4044211004118 100 Creation date 21.01.2024 06:51:04 Subject to technical changes 4
2135.2 价格&库存
很抱歉,暂时无法提供与“2135.2”相匹配的价格&库存,您可以联系我们找货
