2159.2
    CONTA-CLIP
    END PLATE
2159.2 数据手册
Data sheet 2159.2 AP 4 800 V BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 2159.2 Article name AP 4 800 V BG GTIN (EAN) 4044211049829 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.3 g Weight per piece (including packaging) 3.4 g Unit of weight G Customs number 85389099 Country of origin DE Product description End plate Colour Beige Creation date 16.12.2023 21:17:25 Subject to technical changes 1 Data sheet 2159.2 AP 4 800 V BG Technical data Dimensions Length 61 mm Width 1.5 mm Min. thickness 1.5 mm Height 46.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 21:17:25 Subject to technical changes 2 Data sheet 2159.2 AP 4 800 V BG Media Creation date 16.12.2023 21:17:25 Subject to technical changes 3 Data sheet 2159.2 AP 4 800 V BG Accessories ##INVERSE##CONTA-CONNECT Double-level terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 7.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1025.2 RKD 4/800V BG 4044211005658 80 ST Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 7.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1026.2 RKD 4 SV/800V BG 4044211005863 80 ST Creation date 16.12.2023 21:17:25 Subject to technical changes 4
2159.2 价格&库存
很抱歉,暂时无法提供与“2159.2”相匹配的价格&库存,您可以联系我们找货
    • 20+10.1741920+1.27256
