2186.3
    CONTA-CLIP
    END PLATE
2186.3 数据手册
Data sheet 2186.3 AP/SI-2 OG End plate, Width: 1.5 mm, Colour: Orange Business data Article number 2186.3 Article name AP/SI-2 OG GTIN (EAN) 4044211107819 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.98 g Weight per piece (including packaging) 1.99 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2186.2 Product description End plate Creation date 16.12.2023 01:12:04 Subject to technical changes 1 Data sheet 2186.3 AP/SI-2 OG Technical data Dimensions Length 48 mm Width 1.5 mm Min. thickness 1.5 mm Height 24.3 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 01:12:04 No Subject to technical changes 2 Data sheet 2186.3 AP/SI-2 OG Media Creation date 16.12.2023 01:12:04 Subject to technical changes 3 Data sheet 2186.3 AP/SI-2 OG Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1078.2 STK 2 BG 4044211013745 100 Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1190.2 STK 2/15 BG 4044211026585 100 Disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1381.2 STK 2/K BG 4044211044213 100 Disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Blue Article number Article name GTIN (EAN) Packaging unit 1382.5 STK 2/15/K BU 4044211126278 100 Disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1383.2 STKD 1/K BG 4044211044244 50 Creation date 16.12.2023 01:12:04 Subject to technical changes 4
2186.3 价格&库存
很抱歉,暂时无法提供与“2186.3”相匹配的价格&库存,您可以联系我们找货
    • 50+5.8233350+0.72837
