2191.5
2191.5
    CONTA-CLIP
    FUSE DISCONNECT TERMINAL
2191.5 数据手册
Data sheet 2191.5 STK 1/15 BU Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2191.5 Article name STK 1/15 BU GTIN (EAN) 4044211050177 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 12 g Weight per piece (including packaging) 13.11 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 2191.2 Product description Fuse-disconnect terminal Creation date 17.12.2023 20:12:20 Subject to technical changes 1 Data sheet 2191.5 STK 1/15 BU Technical data Dimensions Length 57.5 mm Width 8 mm Height TS 15/5.5 38.5 mm Ratings Rated voltage (determined by the illuminated display and fuse being used) 400 V Rated current (as fuse-disconnect terminal) 6,3 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 / extraction lever Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 20:12:20 Subject to technical changes 2 Data sheet 2191.5 STK 1/15 BU Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type TS 15 Fuse size 5 x 20 / 5 x 25 mm Gauge plug acc. to EN 60 947-1 A4 End plate required Voltage fuse 250 V Power loss in singular arrangement - overload and short-circuit protection, max. 2,5 / 6,3 W / A Power loss in compound arrangement - overload and short-circuit protection, max. 2,5 / 6,3 W / A Power loss in singular arrangement - only short-circuit protection, max. 4 / 6,3 W / A Power loss in compound arrangement - only short-circuit protection, max. 4 / 6,3 W / A Version of fuse holder Swivelling Version of fuse cartridge G fuse 5 x 20 / 5 x 25 Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 20:12:20 No Subject to technical changes 3 Data sheet 2191.5 STK 1/15 BU Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 16 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 16 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 20:12:20 Subject to technical changes 4 Data sheet 2191.5 STK 1/15 BU Media Creation date 17.12.2023 20:12:20 Subject to technical changes 5 Data sheet 2191.5 STK 1/15 BU Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2046.2 AP SI-1 BG 4044211048518 50 Insulated external cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2067.0 AQI 2/8/11 YE 4044211048730 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2069.0 AQI 4/8/11 YE 4044211048754 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2068.0 AQI 3/8/11 YE 4044211048747 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Creation date 17.12.2023 20:12:20 Subject to technical changes 6 Data sheet 2191.5 STK 1/15 BU Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Connecting piece Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2873.3 VBS 2/10 OG 4044211055981 20 ST Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2874.3 VBS 3/10 OG 4044211055998 20 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 17.12.2023 20:12:20 Subject to technical changes 7
2191.5 价格&库存
很抱歉,暂时无法提供与“2191.5”相匹配的价格&库存,您可以联系我们找货
