2194.2
2194.2
    CONTA-CLIP
    DISCONNECT TERMINAL
2194.2 数据手册
Data sheet 2194.2 TK 2/15/K BG Disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Business data Article number 2194.2 Article name TK 2/15/K BG GTIN (EAN) 4044211050214 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 14.6 g Weight per piece (including packaging) 15.26 g Unit of weight G Customs number 85369010 Country of origin DE Prio-Article 2194.2 Product description Disconnect terminal Creation date 17.12.2023 20:14:26 Subject to technical changes 1 Data sheet 2194.2 TK 2/15/K BG Technical data Dimensions Length 57.5 mm Width 8 mm Height TS 15/5.5 38.5 mm Ratings Rated voltage 300 V Rated current 4A Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.13 W Connection data Connection principle Screw connection Connection position Lateral Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 20:14:26 Subject to technical changes 2 Data sheet 2194.2 TK 2/15/K BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type TS 15 Gauge plug acc. to EN 60 947-1 A4 End plate required Version of lengthwise partition Swivelling Environmental Product Compliance REACH Conform No REACH Candidate Substance Note No REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Exception rule 6c Creation date 17.12.2023 20:14:26 Subject to technical changes 3 Data sheet 2194.2 TK 2/15/K BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 16 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 16 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 12 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 12 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 20:14:26 Subject to technical changes 4 Data sheet 2194.2 TK 2/15/K BG Media Creation date 17.12.2023 20:14:26 Subject to technical changes 5 Data sheet 2194.2 TK 2/15/K BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2046.2 AP SI-1 BG 4044211048518 50 Insulated external cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2067.0 AQI 2/8/11 YE 4044211048730 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2069.0 AQI 4/8/11 YE 4044211048754 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2068.0 AQI 3/8/11 YE 4044211048747 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Creation date 17.12.2023 20:14:26 Subject to technical changes 6 Data sheet 2194.2 TK 2/15/K BG Solid link Solid link, Colour: natural Article number Article name GTIN (EAN) Packaging unit 2470.0 KH 5 4044211052607 100 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 17.12.2023 20:14:26 Subject to technical changes 7
2194.2 价格&库存
很抱歉,暂时无法提供与“2194.2”相匹配的价格&库存,您可以联系我们找货
