Data sheet
2315.2 RKD 4/LED2(RD)/60V DC BG
Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5
and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige
Business data
Article number
2315.2
Article name
GTIN (EAN)
4044211051020
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
14 g
Weight per piece (including packaging)
14.77 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Double-level terminals with electronic components
Colour
Beige
Creation date 17.12.2023 20:28:33
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
60.2 mm
Width
6 mm
Height TS 35/7.5
61 mm
Height TS 32
65.5 mm
Ratings
Rated voltage
60 DC V
Rated current
10 A
Rated cross-section
4 mm²
Rated impulse voltage
6 kV
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Screw connection
Connection position
Lateral
Number of terminals per level
2
Number of levels
2
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
4 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
9 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
Technical data
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Mounting rail TS 35/7.5 and TS 32
Gauge plug acc. to EN 60 947-1
A4
Number of cross-connection channels
2
End plate required
Voltage illuminated display
60 DC V
Cross-current via illuminated display
5 mA
Colour of lamp
Red
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
300 V
CSA Usegroup C: rated current
25 A
CSA wire cross-section AWG, min.
22
CSA wire cross-section AWG, max.
12
CSA stripping length
9 mm
CSA torque, max.
1 Nm
CSA torque, min.
0.5 Nm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
500 V
KEMA rated current
32 A
KEMA rated impulse voltage
6 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
Approvals
UL Recognized
UL approval
UL 1059
UL Usegroup C: rated voltage
300 V
UL Usegroup C: rated current
30 A
UL wire cross-section single-core (rigid) AWG, min.
22
UL wire cross-section single-core (rigid) AWG, max.
10
UL wire cross-section stranded AWG, min.
22
UL wire cross-section stranded AWG, max.
10
UL torque
7 Lb In
UL wire material
Cu
UL factory wiring
1
UL field wiring
1
UL Recognized
1
German Lloyd approval
DNV GL Location Classes
C
DNV GL approval granted
1
DNV GL rated cross-section
4 mm²
DNV GL rated current
34 A
DNV GL rated voltage
500 V
DNV GL test standard
IEC 60947-7-1:2002
5
Data sheet
Media
6
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2101.2
AP 4 BG
4044211151652
Insulation plate
Insulation plate, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2566.2
TRS 3 BG
4044211053567
100 ST
Cross-connector
Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm,
Rated cross-section: 4 mm², Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2087.0
Q2
4044211048952
50 ST
Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2089.0
Q4
4044211048976
20 ST
Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2090.0
Q 10
4044211048983
10 ST
7
Data sheet
Cross-connector
Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm,
Article number
Article name
GTIN (EAN)
Packaging
unit
2088.0
Q3
4044211048969
50 ST
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1086.0
SDB 0,6x3,5
4044211014797
1 ST
Socket plug
Socket plug, M 2.5, Colour: natural
Article number
Article name
GTIN (EAN)
Packaging
unit
2075.0
STB 8,5/2,3
4044211048839
50 ST
8
Data sheet
Test plug
Test plug, Colour: Red
Article number
Article name
GTIN (EAN)
Packaging
unit
2007.0
PS 2,3
4044211048105
20 ST
9
