2338.2
2338.2
    CONTA-CLIP
    FEED-THROUGH TERMINAL FOR DIRECT
2338.2 数据手册
Data sheet 2338.2 BKA 4/15 e.B. BG Feed-through terminal for direct mount, Screw connection, Mounting type: Mounting surface, Rated crosssection: 4 mm², Colour: Beige Business data Article number 2338.2 Article name BKA 4/15 e.B. BG GTIN (EAN) 4044211051235 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 70.2 g Weight per piece (including packaging) 71.82 g Unit of weight G Customs number 85369010 Country of origin DE Product description Feed-through terminal for direct mount Colour Beige Creation date 17.12.2023 20:33:41 Subject to technical changes 1 Data sheet 2338.2 BKA 4/15 e.B. BG Technical data Dimensions Length 105.9 mm Height 23 mm Hole spacing (mid-point to mid-point) 98.8 mm Pitch 6 mm Ratings Rated voltage 400 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Screw connection Connection position Lateral Connections 30 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 20:33:41 Subject to technical changes 2 Data sheet 2338.2 BKA 4/15 e.B. BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting face Gauge plug acc. to EN 60 947-1 A3 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 20:33:41 Subject to technical changes 3 Data sheet 2338.2 BKA 4/15 e.B. BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 25 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 12 CSA stripping length 9 mm CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 400 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 17.12.2023 20:33:41 Subject to technical changes 4 Data sheet 2338.2 BKA 4/15 e.B. BG Approvals UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 30 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 20:33:41 Subject to technical changes 5 Data sheet 2338.2 BKA 4/15 e.B. BG Media Creation date 17.12.2023 20:33:41 Subject to technical changes 6 Data sheet 2338.2 BKA 4/15 e.B. BG Accessories Insulated external cross-connector External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 23 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2140.0 AQI 4/6/11 YE 4044211049614 50 ST External insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 59.6 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2141.0 AQI 10/6/11 YE 4044211049621 10 ST External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.8 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2125.0 AQI 2/6/11 YE 4044211049447 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 16.9 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2126.0 AQI 3/6/11 YE 4044211049454 50 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Creation date 17.12.2023 20:33:41 Subject to technical changes 7 Data sheet 2338.2 BKA 4/15 e.B. BG Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Creation date 17.12.2023 20:33:41 Subject to technical changes 8
2338.2 价格&库存
很抱歉,暂时无法提供与“2338.2”相匹配的价格&库存,您可以联系我们找货
