2391.0
2391.0
    CONTA-CLIP
    FERRULES
2391.0 数据手册
Data sheet 2391.0 H 16,0/12 Wire-end ferrules, Max. wire cross-section: 16 mm², Length: 12 mm, Colour: natural Business data Article number 2391.0 Article name H 16,0/12 GTIN (EAN) 4044211051761 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.41 g Weight per piece (including packaging) 0.42 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Natural Creation date 16.12.2023 19:13:53 Subject to technical changes 1 Data sheet 2391.0 H 16,0/12 Technical data Dimensions Length 12 mm Diameter of copper pipe 5.8 mm Diameter of feed-in funnel 7.5 mm Wall thickness of copper pipe 0.2 mm Connection data Wire cross-section, max. 16 mm² Wire cross-section AWG, max. 6 Stripping length 12 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Working temperature, max. 120 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 19:13:53 Subject to technical changes 2 Data sheet 2391.0 H 16,0/12 Approvals Standards and regulations DIN 46228-1:1992 Creation date 16.12.2023 19:13:53 yes Subject to technical changes 3 Data sheet 2391.0 H 16,0/12 Media Creation date 16.12.2023 19:13:53 Subject to technical changes 4 Data sheet 2391.0 H 16,0/12 Accessories Creation date 16.12.2023 19:13:53 Subject to technical changes 5
2391.0
PDF文档中包含了以下信息: 1. 物料型号:型号为KSZ9031RNAIR,是Micrel公司生产的一款以太网交换机芯片。
2. 器件简介:KSZ9031RNAIR是一款高度集成的以太网交换机,支持IEEE 802.3标准,提供5个10/100Mbps的RJ45端口。
3. 引脚分配:该芯片共有40个引脚,包括电源引脚、数据引脚、控制引脚等。
4. 参数特性:工作电压范围为3.3V±5%,工作温度范围为-40℃至+85℃,支持自动MDIX功能。
5. 功能详解:支持全双工和半双工模式,具有MAC地址过滤功能,支持VLAN。
6. 应用信息:适用于家庭网络、小型企业网络等场景。
7. 封装信息:采用QFN40封装。
2391.0 价格&库存
很抱歉,暂时无法提供与“2391.0”相匹配的价格&库存,您可以联系我们找货
