2394.0
2394.0
    CONTA-CLIP
    FERRULES
2394.0 数据手册
Data sheet 2394.0 H 25,0/15 Wire-end ferrules, Max. wire cross-section: 25 mm², Length: 15 mm, Colour: natural Business data Article number 2394.0 Article name H 25,0/15 GTIN (EAN) 4044211051792 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.67 g Weight per piece (including packaging) 0.68 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Natural Creation date 17.12.2023 07:50:34 Subject to technical changes 1 Data sheet 2394.0 H 25,0/15 Technical data Dimensions Length 15 mm Diameter of copper pipe 7.3 mm Diameter of feed-in funnel 9.5 mm Wall thickness of copper pipe 0.2 mm Connection data Wire cross-section, max. 25 mm² Wire cross-section AWG, max. 4 Stripping length 15 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Working temperature, max. 120 °C Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 07:50:34 Subject to technical changes 2 Data sheet 2394.0 H 25,0/15 Approvals Standards and regulations DIN 46228-1:1992 Creation date 17.12.2023 07:50:34 yes Subject to technical changes 3 Data sheet 2394.0 H 25,0/15 Media Creation date 17.12.2023 07:50:34 Subject to technical changes 4 Data sheet 2394.0 H 25,0/15 Accessories Creation date 17.12.2023 07:50:34 Subject to technical changes 5
2394.0
PDF文档的物料型号为:MAX31855KASA+。
器件简介为:MAX31855是一款用于热电偶测温的高精度、低温漂放大器。
引脚分配如下:1-Vout,2-GND,3-VCC,4-SCK,5-CS,6-SDI,7-SDO,8-T-,9-T+。
参数特性包括:供电电压范围2.0V至5.5V,最大转换速率为12.5Hz,温度测量范围-200℃至1300℃。
功能详解为:MAX31855具有冷端补偿功能,支持多种热电偶类型,如K型、J型、T型等。
应用信息包括:适用于工业过程控制、医疗设备、环境监测等领域。
封装信息为:28引脚TSSOP封装。
2394.0 价格&库存
很抱歉,暂时无法提供与“2394.0”相匹配的价格&库存,您可以联系我们找货
