2436.2
2436.2
    CONTA-CLIP
    DOUBLE-LEVEL TERMINAL WITH ELECT
2436.2 数据手册
Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Double-level terminal with electronic components, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Business data Article number 2436.2 Article name RKD 4/LED3(RD)/24V DC BG GTIN (EAN) 4044211052263 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 12.6 g Weight per piece (including packaging) 13.57 g Unit of weight G Customs number 85369010 Country of origin BG Product description Double-level terminals with electronic components Colour Beige Creation date 17.12.2023 20:47:26 Subject to technical changes 1 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Technical data Dimensions Length 60.2 mm Width 6 mm Height TS 35/7.5 61 mm Height TS 32 65.5 mm Ratings Rated voltage 24 DC V Rated current 10 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Number of terminals per level 2 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 20:47:26 Subject to technical changes 2 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7.5 and TS 32 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 2 End plate required Voltage illuminated display 24 DC V Cross-current via illuminated display 5 mA Colour of lamp Red Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 20:47:26 Subject to technical changes 3 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 25 A CSA wire cross-section AWG, min. 22 CSA wire cross-section AWG, max. 12 CSA stripping length 9 mm CSA torque, max. 1 Nm CSA torque, min. 0.5 Nm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 17.12.2023 20:47:26 Subject to technical changes 4 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Approvals UL Recognized UL approval UL 1059 UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 30 A UL wire cross-section single-core (rigid) AWG, min. 22 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 22 UL wire cross-section stranded AWG, max. 10 UL torque 7 Lb In UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 German Lloyd approval DNV GL Location Classes C DNV GL approval granted 1 DNV GL rated cross-section 4 mm² DNV GL rated current 34 A DNV GL rated voltage 500 V DNV GL test standard IEC 60947-7-1:2002 Creation date 17.12.2023 20:47:26 Subject to technical changes 5 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Media Creation date 17.12.2023 20:47:26 Subject to technical changes 6 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2101.2 AP 4 BG 4044211151652 20 Insulation plate Insulation plate, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2566.2 TRS 3 BG 4044211053567 100 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Socket plug Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Test plug Creation date 17.12.2023 20:47:26 Subject to technical changes 7 Data sheet 2436.2 RKD 4/LED3(RD)/24V DC BG Test plug, Colour: Red Article number Article name GTIN (EAN) Packaging unit 2007.0 PS 2,3 4044211048105 20 ST Creation date 17.12.2023 20:47:26 Subject to technical changes 8
2436.2 价格&库存
很抱歉,暂时无法提供与“2436.2”相匹配的价格&库存,您可以联系我们找货
