Data sheet
2461.2 STK 1/15/LED(RD)/60V DC BG
Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4
mm², Width: 8 mm, Colour: Beige
Business data
Article number
2461.2
Article name
GTIN (EAN)
4044211052515
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
12.8 g
Weight per piece (including packaging)
14.18 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Creation date 11.11.2023 07:44:39
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
57.5 mm
Width
8 mm
Height TS 15/5.5
38.5 mm
Ratings
Rated voltage (determined by the illuminated display
and fuse being used)
60 DC V
Rated current (as fuse-disconnect terminal)
6,3 A
Rated cross-section
4 mm²
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Screw connection
Connection position
Lateral
Connections
2 / extraction lever
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
4 mm²
Wire cross-section AWG, min.
22
Wire cross-section AWG, max.
12
Stripping length
9 mm
Screw head
Slotted
Screw threading
M3
Tightening torque, min.
0.5 Nm
Tightening torque, max.
1 Nm
2
Data sheet
Technical data
Further technical data
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Mounting type
TS 15
Fuse size
5 x 20 / 5 x 25 mm
Gauge plug acc. to EN 60 947-1
A4
End plate required
Voltage fuse
250 V
Voltage illuminated display
60 DC V
Cross-current via illuminated display
< 5 mA
Version of fuse holder
Swivelling
Type of display element (defect display)
LED
Version of fuse cartridge
G fuse 5 x 20 / 5 x 25
Supply voltage (defect display), max.
60
Type of voltage (defect display)
DC
Colour of lamp
Red
Print
Colour
Beige
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
3
Data sheet
Media
4
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2046.2
AP SI-1 BG
4044211048518
50
Insulated external cross-connector
External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1
mm, Rated current: 27 A; Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
2067.0
AQI 2/8/11 YE
4044211048730
50 ST
External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3
Article number
Article name
GTIN (EAN)
Packaging
unit
2069.0
AQI 4/8/11 YE
4044211048754
50 ST
External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2
Article number
Article name
GTIN (EAN)
Packaging
unit
2068.0
AQI 3/8/11 YE
4044211048747
50 ST
End stop
End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
2828.0
ES 35/K/ST BG
4044211055547
50
5
Data sheet
Solid link
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
9323.7
PMC SB 8/40 WH
4044211129231
400 ST
Screwdriver
Connecting piece
Connecting sleeve, Colour: Orange
Article number
Article name
GTIN (EAN)
Packaging
unit
2873.3
VBS 2/10 OG
4044211055981
20 ST
Article number
Article name
GTIN (EAN)
Packaging
unit
2874.3
VBS 3/10 OG
4044211055998
20 ST
6
很抱歉,暂时无法提供与“2461.2”相匹配的价格&库存,您可以联系我们找货
