2465.2
    CONTA-CLIP
    FUSE DISCONNECT TERMINAL
2465.2 数据手册
Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Fuse-disconnect terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 8 mm, Colour: Beige Business data Article number 2465.2 Article name STK 1/15/LED(RD)/48V AC BG GTIN (EAN) 4044211052553 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 12.8 g Weight per piece (including packaging) 14.18 g Unit of weight G Customs number 85369010 Country of origin BG Product description Fuse-disconnect terminal Creation date 11.11.2023 07:47:05 Subject to technical changes 1 Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Technical data Dimensions Length 57.5 mm Width 8 mm Height TS 15/5.5 38.5 mm Ratings Rated voltage (determined by the illuminated display and fuse being used) 48 AC V Rated current (as fuse-disconnect terminal) 6,3 A Rated cross-section 4 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Screw connection Connection position Lateral Connections 2 / extraction lever Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 11.11.2023 07:47:05 Subject to technical changes 2 Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Technical data Further technical data Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Mounting type TS 15 Fuse size 5 x 20 / 5 x 25 mm Gauge plug acc. to EN 60 947-1 A4 End plate required Voltage fuse 250 V Voltage illuminated display 48 AC V Cross-current via illuminated display < 5 mA Version of fuse holder Swivelling Type of display element (defect display) LED Version of fuse cartridge G fuse 5 x 20 / 5 x 25 Supply voltage (defect display), max. 48 Type of voltage (defect display) AC Colour of lamp Red Print Colour Beige Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 11.11.2023 07:47:05 Subject to technical changes 3 Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Media Creation date 11.11.2023 07:47:05 Subject to technical changes 4 Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2046.2 AP SI-1 BG 4044211048518 50 Insulated external cross-connector External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 16.1 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2067.0 AQI 2/8/11 YE 4044211048730 50 ST External insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 32.3 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2069.0 AQI 4/8/11 YE 4044211048754 50 ST External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 24.2 mm, Rated current: 27 A; Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 2068.0 AQI 3/8/11 YE 4044211048747 50 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Creation date 11.11.2023 07:47:05 Subject to technical changes 5 Data sheet 2465.2 STK 1/15/LED(RD)/48V AC BG Solid link Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 8 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 9323.7 PMC SB 8/40 WH 4044211129231 400 ST Screwdriver Connecting piece Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2873.3 VBS 2/10 OG 4044211055981 20 ST Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2874.3 VBS 3/10 OG 4044211055998 20 ST Creation date 11.11.2023 07:47:05 Subject to technical changes 6
2465.2 价格&库存
很抱歉,暂时无法提供与“2465.2”相匹配的价格&库存,您可以联系我们找货
  • 10+115.2480110+14.41489
