2541.0
2541.0
    CONTA-CLIP
    CRIMPING CABLE LUG
2541.0 数据手册
Data sheet 2541.0 QKS 6 Crimp lug, Ring shape acc. to DIN 46237, Max. wire cross-section: 6 mm², Colour: Yellow RAL: 1026 Business data Article number 2541.0 Article name QKS 6 GTIN (EAN) 4044211053345 Connector shape Ring shape acc. to DIN 46237 Product-compliant (according to DIN) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 1.7 g Weight per piece (including packaging) 1.73 g Unit of weight G Customs number 85369010 Country of origin TW Product description Crimp Colour Yellow Creation date 15.12.2023 11:51:24 Subject to technical changes 1 Data sheet 2541.0 QKS 6 Technical data Dimensions Length (input to middle of the ring hole) 21 mm Width of ring 8 mm Ring hole diameter 4.3 mm Diameter of feed-in funnel 6.5 mm Size DIN A4-6 Connection data Wire cross-section, min. 4 mm² Wire cross-section, max. 6 mm² Wire cross-section AWG, min. 12 Wire cross-section AWG, max. 10 Materials Connector material Copper Surface Tin-plated insul. Expanded PA insulation Working temperature, min. -55 °C Working temperature, max. 105 °C Further technical data Insulation available Soldered Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 11:51:24 Subject to technical changes 2 Data sheet 2541.0 QKS 6 Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 11:51:24 DIN EN 13599 Subject to technical changes 3 Data sheet 2541.0 QKS 6 Media Creation date 15.12.2023 11:51:24 Subject to technical changes 4 Data sheet 2541.0 QKS 6 Accessories Creation date 15.12.2023 11:51:24 Subject to technical changes 5
2541.0 价格&库存
很抱歉,暂时无法提供与“2541.0”相匹配的价格&库存,您可以联系我们找货
  • 500+4.30817500+0.56018
