2549.0
2549.0
    CONTA-CLIP
    CRIMPING CABLE LUG
2549.0 数据手册
Data sheet 2549.0 FSH 1/2,8 Crimp lug, Spade flat plug shape acc. to DIN 46245 part 1 - 3, Length: 18.8 mm, Max. wire cross-section: 1.5 mm², Colour: Red Business data Article number 2549.0 Article name FSH 1/2,8 GTIN (EAN) 4044211053420 Connector shape Spade flat plug shape acc. to DIN 46245 part 1 - 3 Product-compliant (according to DIN) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 0.72 g Weight per piece (including packaging) 0.73 g Unit of weight G Customs number 85369010 Country of origin TW Product description Crimp Colour Red Creation date 17.12.2023 07:50:34 Subject to technical changes 1 Data sheet 2549.0 FSH 1/2,8 Technical data Dimensions Length 18.8 mm Length of connector 6.4 mm Plug width 2.8 mm Diameter of feed-in funnel 3.5 mm Plug thickness 0.8 mm Connection data Wire cross-section, min. 0.5 mm² Wire cross-section, max. 1.5 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 16 Materials Connector material Copper Surface Tin-plated insul. Expanded PVC insulation Working temperature, min. -10 °C Working temperature, max. 75 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 07:50:34 Subject to technical changes 2 Data sheet 2549.0 FSH 1/2,8 Media Creation date 17.12.2023 07:50:34 Subject to technical changes 3 Data sheet 2549.0 FSH 1/2,8 Accessories Creation date 17.12.2023 07:50:34 Subject to technical changes 4
2549.0 价格&库存
很抱歉,暂时无法提供与“2549.0”相匹配的价格&库存,您可以联系我们找货
