2556.0
2556.0
    CONTA-CLIP
    CRIMPING CABLE LUG
2556.0 数据手册
Data sheet 2556.0 FSH A 2,5 Crimp lug, Length: 21.2 mm, Max. wire cross-section: 2.5 mm², Colour: Blue RAL: Ähnlich 5005 Business data Article number 2556.0 Article name FSH A 2,5 GTIN (EAN) 4044211053499 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 1.51 g Weight per piece (including packaging) 1.56 g Unit of weight G Customs number 85369010 Country of origin TW Product description Crimp Colour Blue Creation date 17.12.2023 07:51:04 Subject to technical changes 1 Data sheet 2556.0 FSH A 2,5 Technical data Dimensions Length 21.2 mm Length of connector 7.8 mm Plug width 6.3 mm Diameter of feed-in funnel 4.3 mm Plug thickness 0.8 mm Connection data Wire cross-section, min. 1.5 mm² Wire cross-section, max. 2.5 mm² Wire cross-section AWG, min. 16 Wire cross-section AWG, max. 14 Materials Connector material Copper Surface Tin-plated insul. Expanded PVC insulation Working temperature, min. -10 °C Working temperature, max. 75 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 07:51:04 Subject to technical changes 2 Data sheet 2556.0 FSH A 2,5 Media Creation date 17.12.2023 07:51:04 Subject to technical changes 3 Data sheet 2556.0 FSH A 2,5 Accessories Creation date 17.12.2023 07:51:04 Subject to technical changes 4
2556.0 价格&库存
很抱歉,暂时无法提供与“2556.0”相匹配的价格&库存,您可以联系我们找货
