2574.2
2574.2
    CONTA-CLIP
    END PLATE
2574.2 数据手册
Data sheet 2574.2 AP 2,5-4/R BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 2574.2 Article name AP 2,5-4/R BG GTIN (EAN) 4044211053659 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 2.65 g Weight per piece (including packaging) 2.68 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2574.2 Product description End plate Creation date 17.12.2023 07:53:29 Subject to technical changes 1 Data sheet 2574.2 AP 2,5-4/R BG Technical data Dimensions Length 57.5 mm Width 1.5 mm Min. thickness 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 07:53:29 No Subject to technical changes 2 Data sheet 2574.2 AP 2,5-4/R BG Media Creation date 17.12.2023 07:53:29 Subject to technical changes 3 Data sheet 2574.2 AP 2,5-4/R BG Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 6 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 1060.2 SL 2,5/35/ZR GNYE 4044211011727 100 ST Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1210.2 RK 2,5-4/ZR BG 4044211028459 100 Creation date 17.12.2023 07:53:29 Subject to technical changes 4
2574.2 价格&库存
很抱歉,暂时无法提供与“2574.2”相匹配的价格&库存,您可以联系我们找货
