2584.5
2584.5
    CONTA-CLIP
    DOUBLE-LEVEL TERMINAL
2584.5 数据手册
Data sheet 2584.5 RKDG 4 BU Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2584.5 Article name RKDG 4 BU GTIN (EAN) 4044211080549 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 15.2 g Weight per piece (including packaging) 16.06 g Unit of weight G Customs number 85369010 Country of origin CZ Prio-Article 2584.2 Product description Double-level terminal Creation date 17.12.2023 21:06:27 Subject to technical changes 1 Data sheet 2584.5 RKDG 4 BU Technical data Dimensions Length 58.5 mm Width 6 mm Height TS 35/7.5 60 mm Ratings Rated voltage 500 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 2.05 W Connection data Connection principle Screw connection Connection position Lateral Connections 2x2 Number of terminals per level 2 Number of levels 2 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 22 Wire cross-section AWG, max. 12 Stripping length 9 mm Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Creation date 17.12.2023 21:06:27 Subject to technical changes 2 Data sheet 2584.5 RKDG 4 BU Technical data Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 21:06:27 Subject to technical changes 3 Data sheet 2584.5 RKDG 4 BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 500 V KEMA rated current 32 A KEMA rated impulse voltage 6 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 17.12.2023 21:06:27 Subject to technical changes 4 Data sheet 2584.5 RKDG 4 BU Media Creation date 17.12.2023 21:06:27 Subject to technical changes 5 Data sheet 2584.5 RKDG 4 BU Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2586.2 APG 4 BG 4044211049089 20 Cross-connector Cross-connector, No. of poles: 2, Mounting type: Can be screwed on, Width: 10.5 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2087.0 Q2 4044211048952 50 ST Cross-connector, No. of poles: 4, Mounting type: Can be screwed on, Width: 22.7 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2089.0 Q4 4044211048976 20 ST Cross-connector, No. of poles: 10, Mounting type: Can be screwed on, Width: 59.3 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2090.0 Q 10 4044211048983 10 ST Cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 16.6 mm, Rated cross-section: 4 mm², Colour: natural Article number Article name GTIN (EAN) Packaging unit 2088.0 Q3 4044211048969 50 ST End stop Creation date 17.12.2023 21:06:27 Subject to technical changes 6 Data sheet 2584.5 RKDG 4 BU End stop, Mounting type: Mounting rail TS 35/7.5, Width: 9.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2828.0 ES 35/K/ST BG 4044211055547 50 Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Creation date 17.12.2023 21:06:27 Subject to technical changes 7
2584.5 价格&库存
很抱歉,暂时无法提供与“2584.5”相匹配的价格&库存,您可以联系我们找货
