2586.2
2586.2
    CONTA-CLIP
    END PLATE
2586.2 数据手册
Data sheet 2586.2 APG 4 BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 2586.2 Article name APG 4 BG GTIN (EAN) 4044211049089 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.2 g Weight per piece (including packaging) 3.32 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2586.2 Product description End plate Creation date 16.12.2023 12:05:22 Subject to technical changes 1 Data sheet 2586.2 APG 4 BG Technical data Dimensions Length 57.4 mm Width 1.5 mm Min. thickness 1.5 mm Height 52.7 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 12:05:22 No Subject to technical changes 2 Data sheet 2586.2 APG 4 BG Media Creation date 16.12.2023 12:05:22 Subject to technical changes 3 Data sheet 2586.2 APG 4 BG Accessories ##INVERSE##CONTA-CONNECT Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2584.2 RKDG 4 BG 4044211080532 100 Ex double-level terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1496.2 RKDG 4 Ex BG 4044211107925 100 Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 2584.2 RKDG 4 BG 4044211080532 100 ##INVERSE##CONTA-CONNECT Double-level terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17048.2 RKDG 4/SV BG 4044211155889 100 Creation date 16.12.2023 12:05:22 Subject to technical changes 4
2586.2 价格&库存
很抱歉,暂时无法提供与“2586.2”相匹配的价格&库存,您可以联系我们找货
