2698.5
2698.5
    CONTA-CLIP
    END PLATE
2698.5 数据手册
Data sheet 2698.5 AP 2,5/I BU End plate, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2698.5 Article name AP 2,5/I BU GTIN (EAN) 4044211054380 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.5 g Weight per piece (including packaging) 3.6 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2698.2 Product description End plate Creation date 17.12.2023 07:50:34 Subject to technical changes 1 Data sheet 2698.5 AP 2,5/I BU Technical data Dimensions Length 59.85 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 07:50:34 No Subject to technical changes 2 Data sheet 2698.5 AP 2,5/I BU Media Creation date 17.12.2023 07:50:34 Subject to technical changes 3 Data sheet 2698.5 AP 2,5/I BU Accessories ##INVERSE##CONTA-CONNECT Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1271.2 IK 2,5 PNP/DC/LED(RD)/48V BG 4044211037512 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1260.2 IK 2,5 BG 4044211035228 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1263.2 IK 2,5 PNP/DC/LED(GN)/24V BG 4044211035860 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1274.2 IK 2,5 PNP/DC/LED(GN)/60V BG 4044211037628 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1275.2 IK 2,5 PNP/AC/LED(RD)/220V BG 4044211037734 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1280.2 IK 2,5 NPN/DC/LED(GN)/60V BG 4044211038373 100 ST Creation date 17.12.2023 07:50:34 Subject to technical changes 4 Data sheet 2698.5 AP 2,5/I BU ##INVERSE##CONTA-CONNECT Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1282.2 IK 2,5 NPN/AC/LED(GN)/220V BG 4044211038663 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1264.2 IK 2,5 NPN/DC/LED(RD)/24V BG 4044211036072 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1277.2 IK 2,5 NPN/DC/LED(RD)/48V BG 4044211037918 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1278.2 IK 2,5 NPN/DC/LED(GN)/48V BG 4044211038021 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1281.2 IK 2,5 NPN/AC/LED(RD)/220V BG 4044211038557 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1262.2 IK 2,5 PNP/DC/LED(RD)/24V BG 4044211035655 100 ST Creation date 17.12.2023 07:50:34 Subject to technical changes 5 Data sheet 2698.5 AP 2,5/I BU ##INVERSE##CONTA-CONNECT Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1265.2 IK 2,5 NPN/DC/LED(GN)/24V BG 4044211036287 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1272.2 IK 2,5 PNP/DC/LED(GN)/48V BG 4044211037567 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1276.2 IK 2,5 PNP/AC/LED(GN)220V BG 4044211037840 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1279.2 IK 2,5 NPN/DC/LED(RD)/ 60V BG 4044211038168 100 ST Three-level initiator terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 2.5 mm², Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1273.2 IK 2,5 PNP/DC/LED(RD)/60V BG 4044211037574 100 ST Creation date 17.12.2023 07:50:34 Subject to technical changes 6
2698.5 价格&库存
很抱歉,暂时无法提供与“2698.5”相匹配的价格&库存,您可以联系我们找货
