2738.2
2738.2
    CONTA-CLIP
    END PLATE
2738.2 数据手册
Data sheet 2738.2 AP 1,5-4 BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 2738.2 Article name AP 1,5-4 BG GTIN (EAN) 4044211054748 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 1.02 g Weight per piece (including packaging) 1.08 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2738.2 Product description End plate Creation date 17.12.2023 08:04:50 Subject to technical changes 1 Data sheet 2738.2 AP 1,5-4 BG Technical data Dimensions Length 27 mm Width 1.5 mm Min. thickness 1.5 mm Height 1.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 08:04:50 Subject to technical changes 2 Data sheet 2738.2 AP 1,5-4 BG Media Creation date 17.12.2023 08:04:50 Subject to technical changes 3 Data sheet 2738.2 AP 1,5-4 BG Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1010.2 RK 1,5-4/15 BG 4044211002275 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1015.2 RK 1,5-4 BG 4044211003425 100 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type: Mounting rail TS 15/5.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1433.2 RK 1,5-4/15 Ex BG 4044211044817 100 Creation date 17.12.2023 08:04:50 Subject to technical changes 4
2738.2 价格&库存
很抱歉,暂时无法提供与“2738.2”相匹配的价格&库存,您可以联系我们找货
