2751.2
2751.2
    CONTA-CLIP
    INSULATED CROSS CONNECTOR
2751.2 数据手册
Data sheet 2751.2 QI 3 YE Insulated cross-connector, No. of poles: 3, Mounting type: Can be screwed on, Width: 21.7 mm, Colour: Yellow RAL: 1026 Business data Article number 2751.2 Article name QI 3 YE GTIN (EAN) 4044211054878 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 6.96 g Weight per piece (including packaging) 6.99 g Unit of weight G Customs number 85389099 Country of origin CZ Product description Insulated cross-connector Colour Yellow Creation date 17.12.2023 08:08:01 Subject to technical changes 1 Data sheet 2751.2 QI 3 YE Technical data Dimensions Length 2.4 mm Width 21.7 mm Pitch size 8 mm Ratings Voltage with partition, max. 800 V Voltage without partition, max. 400 V Rated current 57 A Contamination degree 3 Connection data No. of poles 3 Screw head Slotted Screw threading M3 Tightening torque, min. 0.5 Nm Tightening torque, max. 1 Nm Materials Material Copper Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Screwable Insulation available Number of bridged terminals Creation date 17.12.2023 08:08:01 3 Subject to technical changes 2 Data sheet 2751.2 QI 3 YE Technical data Environmental Product Compliance REACH Conform No REACH Reference date 2023-06-14 REACH Candidate Substance Note No REACH CAS 1 Substance LEAD REACH CAS 1 Percent minimal 0.1 % REACH CAS 1 Percent maximum 4% REACH CAS 1 Number 7439-92-1 RoHS Conform yes RoHS Exception rule 6c Creation date 17.12.2023 08:08:01 Subject to technical changes 3 Data sheet 2751.2 QI 3 YE Media Creation date 17.12.2023 08:08:01 Subject to technical changes 4 Data sheet 2751.2 QI 3 YE Accessories Screwdriver Screwdriver with bare blade, Colour: Black-grey Article number Article name GTIN (EAN) Packaging unit 1086.0 SDB 0,6x3,5 4044211014797 1 ST ##INVERSE##CONTA-CONNECT Feed-through terminal for direct mount/block variant, Screw connection, Mounting type: Mounting surface, Rated cross-section: 10 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1386.2 KBL 6-10/10-D BG 4044211044275 10 Feed-through terminal/block variant, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1006.2 KBL 6-10 BG 4044211001414 10 ST Feed-through terminal for direct mount/block variant, Screw connection, Mounting type: Mounting surface, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1389.2 KBL 6-10-D BG 4044211044305 100 Five-wire mains-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1525.2 FNAB 6-10 4044211046804 10 ST Creation date 17.12.2023 08:08:01 Subject to technical changes 5 Data sheet 2751.2 QI 3 YE ##INVERSE##CONTA-CONNECT Feed-through terminal/block variant, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1007.2 KBL 6-10 m.B. BG 4044211001629 10 ST Four-wire motor-connection block, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Colour: Multi-coloured Article number Article name GTIN (EAN) Packaging unit 1522.2 VMAB 6-10 4044211046699 10 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1134.2 PTK 10/DU BG 4044211020293 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1130.2 PTK 10/LT BG 4044211019853 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1131.2 PTK 10/LT/STB BG 4044211019969 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1132.2 PTK 10/QT BG 4044211020071 50 ST Creation date 17.12.2023 08:08:01 Subject to technical changes 6 Data sheet 2751.2 QI 3 YE ##INVERSE##CONTA-CONNECT Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1133.2 PTK 10/QT/STB BG 4044211020187 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1135.2 PTK 10/DU/STB BG 4044211020408 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17366.2 PTK 10/LT/HB BG 4044211185145 50 ST Test disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17367.2 PTK 10/LT/STB/HB BG 4044211185152 50 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1168.2 RK 6-10/35/SAS BG 4044211128630 100 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1005.2 RK 6-10 BG 4044211001148 100 Creation date 17.12.2023 08:08:01 Subject to technical changes 7 Data sheet 2751.2 QI 3 YE ##INVERSE##CONTA-CONNECT Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black-yellow Article number Article name GTIN (EAN) Packaging unit 1564.2 RK 6-10/PE BKYE 4044211047351 100 ST Feed-through terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1578.2 RK 6-10/35 BG 4044211047627 100 Creation date 17.12.2023 08:08:01 Subject to technical changes 8
2751.2 价格&库存
很抱歉,暂时无法提供与“2751.2”相匹配的价格&库存,您可以联系我们找货
