2762.4
    CONTA-CLIP
    END PLATE
2762.4 数据手册
Data sheet 2762.4 AP 10 BK End plate, Width: 2 mm, Colour: Black RAL: 9005 Business data Article number 2762.4 Article name AP 10 BK GTIN (EAN) 4044211127114 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.85 g Weight per piece (including packaging) 2.9 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2762.2 Product description End plate Creation date 17.12.2023 08:08:10 Subject to technical changes 1 Data sheet 2762.4 AP 10 BK Technical data Dimensions Length 60.49 mm Width 2 mm Min. thickness 2 mm Height 33.8 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:08:10 No Subject to technical changes 2 Data sheet 2762.4 AP 10 BK Media Creation date 17.12.2023 08:08:10 Subject to technical changes 3 Data sheet 2762.4 AP 10 BK Accessories ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1104.2 SIK 10/LED(RD)/20-30V DC/40-60V AC BG 4044211016753 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1103.2 SIK 10/LED(RD)/12V DC/24V AC BG 4044211016548 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1105.2 SIK 10/LED(RD)/40-60V DC/80-120V AC BG 4044211016906 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1107.2 SIK 10/2 LED´s(RD)/24V DC BG 4044211016920 25 ST Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1106.2 SIK 10/LED(RD)/115V DC/230V AC BG 4044211016913 25 Fused terminal with disconnect plug, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17042.2 SIK 10/ST BG 4044211155797 25 Creation date 17.12.2023 08:08:10 Subject to technical changes 4 Data sheet 2762.4 AP 10 BK ##INVERSE##CONTA-CONNECT Fuse-disconnect terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1101.2 SIK 10 BG 4044211016388 50 Fused terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 17364.4 SIK 10 PA-G BK 4044211178406 50 ST Fused terminal with disconnect plug, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 10 mm², Width: 8 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 17044.2 SIK 10/ST/5x20 BG 4044211155827 25 ST Creation date 17.12.2023 08:08:10 Subject to technical changes 5
2762.4 价格&库存
很抱歉,暂时无法提供与“2762.4”相匹配的价格&库存,您可以联系我们找货
    • 20+12.4013020+1.55112
