2767.2
    CONTA-CLIP
    INSULATED EXTERNAL CROSS CONNECT
2767.2 数据手册
Data sheet 2767.2 AQI 2/150 YE External insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 56.13 mm, Rated current: 309 A; Colour: Yellow RAL: 1026 Business data Article number 2767.2 Article name AQI 2/150 YE GTIN (EAN) 4044211054977 Packaging unit 5 Quantity unit PC Weight per piece (not including packaging) 156.8 g Weight per piece (including packaging) 156.9 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2767.2 Product description External insulated cross-connector Creation date 15.12.2023 02:10:57 Subject to technical changes 1 Data sheet 2767.2 AQI 2/150 YE Technical data Dimensions Width 56.13 mm Pitch size 31 mm Ratings Voltage with partition, max. 1000 V Voltage without partition, max. 1000 V Rated current 309 A Contamination degree 3 Connection data No. of poles 2 Materials Material Copper Surface Tin-plated Insulation housing Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Mounting type Plug in Insulation available Touch protection is available Number of bridged terminals 2 Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 02:10:57 No Subject to technical changes 2 Data sheet 2767.2 AQI 2/150 YE Media Creation date 15.12.2023 02:10:57 Subject to technical changes 3 Data sheet 2767.2 AQI 2/150 YE Accessories ##INVERSE##CONTA-CONNECT Feed-through terminal to mounting surface, Screw connection, Mounting type: Mounting surface, Rated cross-section: 150 mm², Width: 31 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1584.2 RK 150-D BG 4044211047740 5 Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 150 mm², Width: 31 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1477.2 RK 150 Ex BG 4044211107864 5 Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS 32, Rated cross-section: 150 mm², Width: 31 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1124.2 RK 150 BG 4044211019198 5 Creation date 15.12.2023 02:10:57 Subject to technical changes 4
2767.2 价格&库存
很抱歉,暂时无法提供与“2767.2”相匹配的价格&库存,您可以联系我们找货
  • 5+188.286285+23.55030
