Data sheet
2770.2 AQI 3/240 YE
External insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 103.12 mm, Rated current:
380 A; Colour: Yellow
RAL: 1026
Business data
Article number
2770.2
Article name
AQI 3/240 YE
GTIN (EAN)
4044211055004
Packaging unit
5
Quantity unit
PC
Weight per piece (not including packaging)
317.84 g
Weight per piece (including packaging)
319.2 g
Unit of weight
G
Customs number
85389099
Country of origin
DE
Prio-Article
2770.2
Product description
Creation date 17.12.2023 08:08:26
Subject to technical changes
1
Data sheet
2770.2 AQI 3/240 YE
Technical data
Dimensions
Width
103.12 mm
Pitch size
36 mm
Ratings
Voltage with partition, max.
1000 V
Voltage without partition, max.
1000 V
Rated current
380 A
Contamination degree
3
Connection data
No. of poles
3
Materials
Material
Copper
Surface
Tin-plated
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-2
Working temperature, min.
-40 °C
Working temperature, max.
105 °C
Further technical data
Mounting type
Plug in
Insulation available
Touch protection is available
Number of bridged terminals
3
Environmental Product Compliance
REACH Candidate Substance Note
No
2
Data sheet
2770.2 AQI 3/240 YE
Media
3
Data sheet
2770.2 AQI 3/240 YE
Accessories
##INVERSE##CONTA-CONNECT
Feed-through terminal, Screw connection, Mounting type:Mounting rail TS 35/7.5 and TS
32, Rated cross-section: 240 mm², Width: 36 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1126.2
RK 240 BG
4044211019419
5
Ex feed-through terminal ATEX-certified, Screw connection, Mounting type:Mounting rail
TS 35/7.5 and TS 32, Rated cross-section: 240 mm², Width: 36 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
1485.2
RK 240 Ex BG
4044211107888
5
Feed-through terminal for direct mount, Screw connection, Mounting surface, Rated
Article number
Article name
GTIN (EAN)
Packaging
unit
1585.2
RK 240-D BG
4044211047764
5
4
很抱歉,暂时无法提供与“2770.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+318.225165+41.20064
