2788.0
2788.0
    CONTA-CLIP
    FERRULES
2788.0 数据手册
Data sheet 2788.0 H 120,0/50 BU Wire-end ferrules, Max. wire cross-section: 120 mm², Length: 50 mm, Length of copper pipe: 30 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2788.0 Article name H 120,0/50 BU GTIN (EAN) 4044211055172 Packaging unit 25 Quantity unit PC Weight per piece (not including packaging) 9.04 g Weight per piece (including packaging) 9.21 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Blue Creation date 17.12.2023 08:03:24 Subject to technical changes 1 Data sheet 2788.0 H 120,0/50 BU Technical data Dimensions Length 50 mm Length of copper pipe 30 mm Diameter of copper pipe 16.5 mm Diameter plastic collar 21 mm Wall thickness of copper pipe 0.5 mm Wall thickness of plastic collar 0.7 mm Connection data Wire cross-section, max. 120 mm² Wire cross-section AWG, max. 4/0 Stripping length 36 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 08:03:24 Subject to technical changes 2 Data sheet 2788.0 H 120,0/50 BU Approvals Standards and regulations DIN 46228-4:1990 Creation date 17.12.2023 08:03:24 yes Subject to technical changes 3 Data sheet 2788.0 H 120,0/50 BU Media Creation date 17.12.2023 08:03:24 Subject to technical changes 4 Data sheet 2788.0 H 120,0/50 BU Accessories Creation date 17.12.2023 08:03:24 Subject to technical changes 5
2788.0 价格&库存
很抱歉,暂时无法提供与“2788.0”相匹配的价格&库存,您可以联系我们找货
