2794.0
    CONTA-CLIP
    FERRULES
2794.0 数据手册
Data sheet 2794.0 HZL/0,5-D WH Wire-end ferrules, Max. wire cross-section: 0.5 mm², Length: 14 mm, Length of copper pipe: 8 mm, Colour: White RAL: 9010 Business data Article number 2794.0 Article name HZL/0,5-D WH GTIN (EAN) 4044211055233 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.1 g Weight per piece (including packaging) 0.11 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour White Creation date 17.12.2023 08:03:40 Subject to technical changes 1 Data sheet 2794.0 HZL/0,5-D WH Technical data Dimensions Length 14 mm Length of copper pipe 8 mm Width of plastic collar 3 mm Height of plastic collar 5 mm Diameter of copper pipe 1.4 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.3 mm Connection data Wire cross-section, max. 0.5 mm² Wire cross-section AWG, max. 20 Stripping length 11 mm 2-wire plastic collar Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 08:03:40 Subject to technical changes 2 Data sheet 2794.0 HZL/0,5-D WH Approvals Standards and regulations DIN 46228-4:1990 Creation date 17.12.2023 08:03:40 yes Subject to technical changes 3 Data sheet 2794.0 HZL/0,5-D WH Media Creation date 17.12.2023 08:03:40 Subject to technical changes 4 Data sheet 2794.0 HZL/0,5-D WH Accessories Creation date 17.12.2023 08:03:40 Subject to technical changes 5
2794.0
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
2794.0 价格&库存
很抱歉,暂时无法提供与“2794.0”相匹配的价格&库存,您可以联系我们找货
  • 500+0.91159500+0.11402
