28342.7
28342.7
    CONTA-CLIP
    TERMINAL MARKER/PC CARD
28342.7 数据手册
Data sheet 28342.7 PC-SB 5X5/48 WH Terminal marker / PC Card, Length: 5 mm, Width: 5 mm, Colour: White RAL: 9010 Business data Article number 28342.7 Article name PC-SB 5X5/48 WH GTIN (EAN) 4044211210380 Packaging unit 960 Quantity unit PC Number of markers per card 48 ST Weight per piece (not including packaging) 0.17 g Weight per piece (including packaging) 0.2 g Unit of weight G Customs number 39269097 Country of origin DE Product description Terminal marker / PC Card Colour White Creation date 14.12.2023 18:34:43 Subject to technical changes 1 Data sheet 28342.7 PC-SB 5X5/48 WH Technical data Dimensions Length 5 mm Width 5 mm Materials Marker material Polycarbonate Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 130 °C Halogen-free Silicone-free Further technical data Mounting Joined together Software code 402 Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 18:34:43 Subject to technical changes 2 Data sheet 28342.7 PC-SB 5X5/48 WH Media Creation date 14.12.2023 18:34:43 Subject to technical changes 3 Data sheet 28342.7 PC-SB 5X5/48 WH Accessories Printer The thermal transfer printing system for marking labels and signs for terminal blocks, cables and lines, devices, channels, input/output devices and external control panels. The CONTAPrintMAX software is available for download at www.conta-clip.com. Article number Article name GTIN (EAN) Packaging unit 33000.0 TTPCardMAX 4044211246501 1 ST ##INVERSE##CONTA-CONNECT Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27046.6 PVMAK 2,5 GR 4044211227289 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27047.6 PVMAK 2,5/SV GR 4044211227296 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27048.6 PIKD 2,5/1PE/L/L GR 4044211227173 50 ST Three-level initiator terminal | Multi-wire terminal,Push-in-connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5,1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27039.6 PIKD 2,5 GR 4044211227210 50 Creation date 14.12.2023 18:34:43 Subject to technical changes 4 Data sheet 28342.7 PC-SB 5X5/48 WH ##INVERSE##CONTA-CONNECT Three-level initiator terminal | Multi-wire terminal,Push-in-connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5,1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27039.6 PIKD 2,5 GR 4044211227210 50 Three-level initiator terminal | Multi-wire terminal,Push-in-connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5,1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27040.2 PIKD 2,5/SV/PE GNYE 4044211227227 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27042.6 PIKD 2,5/PE/L/L GR 4044211227258 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27043.6 PIKD 2,5/PE/L/N GR 4044211227265 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27045.6 PIKD 2,5/L/L/N GR 4044211227272 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27049.6 PIKD 2,5/1PE/L/N GR 4044211227180 50 ST Creation date 14.12.2023 18:34:43 Subject to technical changes 5 Data sheet 28342.7 PC-SB 5X5/48 WH ##INVERSE##CONTA-CONNECT Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27050.6 PIKD 2,5/1/L/L GR 4044211227302 50 ST Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27050.6 PIKD 2,5/1/L/L GR 4044211227302 50 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 27007.2 PSL 2,5/2A GNYE 4044211223809 50 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 27011.2 PSL 2,5/4A GNYE 4044211223885 50 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27008.6 PRK 2,5/3A GR 4044211223830 50 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27010.6 PRK 2,5/4A GR 4044211223878 50 Creation date 14.12.2023 18:34:43 Subject to technical changes 6 Data sheet 28342.7 PC-SB 5X5/48 WH ##INVERSE##CONTA-CONNECT Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 27009.2 PSL 2,5/3A GNYE 4044211223847 50 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 27007.2 PSL 2,5/2A GNYE 4044211223809 50 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 27011.2 PSL 2,5/4A GNYE 4044211223885 50 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27008.6 PRK 2,5/3A GR 4044211223830 50 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27010.6 PRK 2,5/4A GR 4044211223878 50 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27006.6 PRK 2,5/2A GR 4044211223793 50 Creation date 14.12.2023 18:34:43 Subject to technical changes 7 Data sheet 28342.7 PC-SB 5X5/48 WH ##INVERSE##CONTA-CONNECT Three-level initiator terminal | Multi-wire terminal,Push-in-connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5,1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27039.6 PIKD 2,5 GR 4044211227210 50 ##INVERSE##CONTA-CONNECT Three-level initiator terminal |Multi-wire terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 27042.6 PIKD 2,5/PE/L/L GR 4044211227258 50 ST Creation date 14.12.2023 18:34:43 Subject to technical changes 8
28342.7 价格&库存
很抱歉,暂时无法提供与“28342.7”相匹配的价格&库存,您可以联系我们找货
