2856.0
2856.0
    CONTA-CLIP
    FERRULES
2856.0 数据手册
Data sheet 2856.0 H 16,0/28-D BU Wire-end ferrules, Max. wire cross-section: 16 mm², Length: 28 mm, Length of copper pipe: 18 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 2856.0 Article name H 16,0/28-D BU GTIN (EAN) 4044211055813 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 0.87 g Weight per piece (including packaging) 0.88 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Blue Creation date 14.12.2023 20:01:33 Subject to technical changes 1 Data sheet 2856.0 H 16,0/28-D BU Technical data Dimensions Length 28 mm Length of copper pipe 18 mm Diameter of copper pipe 5.8 mm Diameter plastic collar 8.8 mm Wall thickness of copper pipe 0.2 mm Wall thickness of plastic collar 0.4 mm Connection data Wire cross-section, max. 16 mm² Wire cross-section AWG, max. 6 Stripping length 21 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 20:01:33 Subject to technical changes 2 Data sheet 2856.0 H 16,0/28-D BU Approvals Standards and regulations DIN 46228-4:1990 Creation date 14.12.2023 20:01:33 yes Subject to technical changes 3 Data sheet 2856.0 H 16,0/28-D BU Media Creation date 14.12.2023 20:01:33 Subject to technical changes 4 Data sheet 2856.0 H 16,0/28-D BU Accessories Creation date 14.12.2023 20:01:33 Subject to technical changes 5
2856.0 价格&库存
很抱歉,暂时无法提供与“2856.0”相匹配的价格&库存,您可以联系我们找货
