2862.2
2862.2
    CONTA-CLIP
    END PLATE
2862.2 数据手册
Data sheet 2862.2 AP VMAK 2,5 BG End plate, Width: 2 mm, Colour: Beige Business data Article number 2862.2 Article name AP VMAK 2,5 BG GTIN (EAN) 4044211055875 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 6.5 g Weight per piece (including packaging) 6.57 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 2862.2 Product description End plate Creation date 15.12.2023 19:48:19 Subject to technical changes 1 Data sheet 2862.2 AP VMAK 2,5 BG Technical data Dimensions Length 91.15 mm Width 2 mm Min. thickness 2 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Further technical data Designed as end plate Snap-on available Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 19:48:19 No Subject to technical changes 2 Data sheet 2862.2 AP VMAK 2,5 BG Media Creation date 15.12.2023 19:48:19 Subject to technical changes 3 Data sheet 2862.2 AP VMAK 2,5 BG Accessories ##INVERSE##CONTA-CONNECT Motor-connection terminal, Screw connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 6 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 1425.2 VMAK 2,5 BG 4044211044701 40 ST Creation date 15.12.2023 19:48:19 Subject to technical changes 4
2862.2 价格&库存
很抱歉,暂时无法提供与“2862.2”相匹配的价格&库存,您可以联系我们找货
    • 20+15.3146420+1.98378
