2869.0
    CONTA-CLIP
    FERRULES
2869.0 数据手册
Data sheet 2869.0 H 0,75/18-D GR Wire-end ferrules, Max. wire cross-section: 0.75 mm², Length: 18 mm, Length of copper pipe: 12 mm, Colour: Grey RAL: 7032 Business data Article number 2869.0 Article name H 0,75/18-D GR GTIN (EAN) 4044211055943 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.1 g Weight per piece (including packaging) 0.11 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Grey Creation date 15.12.2023 18:35:23 Subject to technical changes 1 Data sheet 2869.0 H 0,75/18-D GR Technical data Dimensions Length 18 mm Length of copper pipe 12 mm Diameter of copper pipe 1.2 mm Diameter plastic collar 2.8 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.25 mm Connection data Wire cross-section, max. 0.75 mm² Wire cross-section AWG, max. 18 Stripping length 14 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 18:35:23 Subject to technical changes 2 Data sheet 2869.0 H 0,75/18-D GR Approvals Standards and regulations DIN 46228-4:1990 Creation date 15.12.2023 18:35:23 yes Subject to technical changes 3 Data sheet 2869.0 H 0,75/18-D GR Media Creation date 15.12.2023 18:35:23 Subject to technical changes 4 Data sheet 2869.0 H 0,75/18-D GR Accessories Creation date 15.12.2023 18:35:23 Subject to technical changes 5
2869.0 价格&库存
很抱歉,暂时无法提供与“2869.0”相匹配的价格&库存,您可以联系我们找货
