3025.0
    CONTA-CLIP
    FERRULES
3025.0 数据手册
Data sheet 3025.0 HZL 16,0 L GN Wire-end ferrules, Max. wire cross-section: 16 mm², Length: 38 mm, Length of copper pipe: 25 mm, Colour: Green Business data Article number 3025.0 Article name HZL 16,0 L GN GTIN (EAN) 4044211057398 Packaging unit 50 Quantity unit PC Weight per piece (not including packaging) 0.21 g Weight per piece (including packaging) 0.22 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Green Creation date 15.12.2023 06:25:19 Subject to technical changes 1 Data sheet 3025.0 HZL 16,0 L GN Technical data Dimensions Length 38 mm Length of copper pipe 25 mm Width of plastic collar 9.5 mm Height of plastic collar 17.2 mm Diameter of copper pipe 8.3 mm Wall thickness of copper pipe 0.3 mm Wall thickness of plastic collar 0.6 mm Connection data Wire cross-section, max. 16 mm² Wire cross-section AWG, max. 6 Stripping length 29 mm 2-wire plastic collar Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 06:25:19 Subject to technical changes 2 Data sheet 3025.0 HZL 16,0 L GN Approvals Standards and regulations DIN 46228-4:1990 Creation date 15.12.2023 06:25:19 yes Subject to technical changes 3 Data sheet 3025.0 HZL 16,0 L GN Media Creation date 15.12.2023 06:25:19 Subject to technical changes 4 Data sheet 3025.0 HZL 16,0 L GN Accessories Creation date 15.12.2023 06:25:19 Subject to technical changes 5
3025.0 价格&库存
很抱歉,暂时无法提供与“3025.0”相匹配的价格&库存,您可以联系我们找货
