3030.0
3030.0
    CONTA-CLIP
    FERRULES
3030.0 数据手册
Data sheet 3030.0 HZL 0,75 HL-T LB Wire-end ferrules, Max. wire cross-section: 0.75 mm², Length: 16 mm, Length of copper pipe: 10 mm, Colour: Light-blue Business data Article number 3030.0 Article name HZL 0,75 HL-T LB GTIN (EAN) 4044211057411 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.21 g Weight per piece (including packaging) 0.22 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Light-blue Creation date 17.12.2023 08:32:29 Subject to technical changes 1 Data sheet 3030.0 HZL 0,75 HL-T LB Technical data Dimensions Length 16 mm Length of copper pipe 10 mm Width of plastic collar 3 mm Height of plastic collar 5.5 mm Diameter of copper pipe 1.7 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.3 mm Connection data Wire cross-section, max. 0.75 mm² Wire cross-section AWG, max. 18 Stripping length 13 mm 2-wire plastic collar Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 08:32:29 Subject to technical changes 2 Data sheet 3030.0 HZL 0,75 HL-T LB Approvals Standards and regulations DIN 46228-4:1990 Creation date 17.12.2023 08:32:29 yes Subject to technical changes 3 Data sheet 3030.0 HZL 0,75 HL-T LB Media Creation date 17.12.2023 08:32:29 Subject to technical changes 4 Data sheet 3030.0 HZL 0,75 HL-T LB Accessories Creation date 17.12.2023 08:32:29 Subject to technical changes 5
3030.0 价格&库存
很抱歉,暂时无法提供与“3030.0”相匹配的价格&库存,您可以联系我们找货
