3040.0
    CONTA-CLIP
    FERRULES
3040.0 数据手册
Data sheet 3040.0 HZL 2,5 L-T GR Wire-end ferrules, Max. wire cross-section: 2.5 mm², Length: 27 mm, Length of copper pipe: 18 mm, Colour: Grey RAL: 7032 Business data Article number 3040.0 Article name HZL 2,5 L-T GR GTIN (EAN) 4044211057459 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 0.21 g Weight per piece (including packaging) 0.22 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Grey Creation date 15.12.2023 11:26:22 Subject to technical changes 1 Data sheet 3040.0 HZL 2,5 L-T GR Technical data Dimensions Length 27 mm Length of copper pipe 18 mm Width of plastic collar 4.5 mm Height of plastic collar 8 mm Diameter of copper pipe 2.8 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.4 mm Connection data Wire cross-section, max. 2.5 mm² Wire cross-section AWG, max. 14 Stripping length 21 mm 2-wire plastic collar Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 11:26:22 Subject to technical changes 2 Data sheet 3040.0 HZL 2,5 L-T GR Approvals Standards and regulations DIN 46228-4:1990 Creation date 15.12.2023 11:26:22 yes Subject to technical changes 3 Data sheet 3040.0 HZL 2,5 L-T GR Media Creation date 15.12.2023 11:26:22 Subject to technical changes 4 Data sheet 3040.0 HZL 2,5 L-T GR Accessories Creation date 15.12.2023 11:26:22 Subject to technical changes 5
3040.0 价格&库存
很抱歉,暂时无法提供与“3040.0”相匹配的价格&库存,您可以联系我们找货
