3065.0
3065.0
    CONTA-CLIP
    CRIMPING CABLE LUG
3065.0 数据手册
Data sheet 3065.0 QKS G 1 Crimp lug, Fork shape acc. to DIN 46237/C, Max. wire cross-section: 1 mm², Colour: Red Business data Article number 3065.0 Article name QKS G 1 GTIN (EAN) 4044211057701 Connector shape Fork shape acc. to DIN 46237/C Product-compliant (according to DIN) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 0.89 g Weight per piece (including packaging) 0.9 g Unit of weight G Customs number 85369010 Country of origin TW Product description Crimp Colour Red Creation date 16.12.2023 11:39:09 Subject to technical changes 1 Data sheet 3065.0 QKS G 1 Technical data Dimensions Length (input to end of inner fork ring) 19 mm Outer width of fork 10 mm Inner width of fork 5.3 mm Diameter of feed-in funnel 4.1 mm Size DIN C5-1 Connection data Wire cross-section, min. 0.5 mm² Wire cross-section, max. 1 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 18 Materials Connector material Copper Surface Tin-plated insul. Expanded PA insulation Working temperature, min. -55 °C Working temperature, max. 105 °C Further technical data Insulation available Soldered Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 16.12.2023 11:39:09 Subject to technical changes 2 Data sheet 3065.0 QKS G 1 Approvals Standards and regulations Standards / specifications Creation date 16.12.2023 11:39:09 DIN EN 13599 Subject to technical changes 3 Data sheet 3065.0 QKS G 1 Media Creation date 16.12.2023 11:39:09 Subject to technical changes 4 Data sheet 3065.0 QKS G 1 Accessories Creation date 16.12.2023 11:39:09 Subject to technical changes 5
3065.0 价格&库存
很抱歉,暂时无法提供与“3065.0”相匹配的价格&库存,您可以联系我们找货
  • 100+3.05398100+0.39711
