3068.0
3068.0
    CONTA-CLIP
    CRIMPING CABLE LUG
3068.0 数据手册
Data sheet 3068.0 QKS G 2,5 Crimp lug, Fork shape acc. to DIN 46237/C, Max. wire cross-section: 2.5 mm², Colour: Blue RAL: Ähnlich 5005 Business data Article number 3068.0 Article name QKS G 2,5 GTIN (EAN) 4044211057732 Connector shape Fork shape acc. to DIN 46237/C Product-compliant (according to DIN) yes Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 1.13 g Weight per piece (including packaging) 1.14 g Unit of weight G Customs number 85369010 Country of origin TW Product description Crimp Colour Blue Creation date 15.12.2023 10:43:30 Subject to technical changes 1 Data sheet 3068.0 QKS G 2,5 Technical data Dimensions Length (input to end of inner fork ring) 20 mm Outer width of fork 10 mm Inner width of fork 5.3 mm Diameter of feed-in funnel 4.5 mm Size DIN C 5 - 2,5 Connection data Wire cross-section, min. 1.5 mm² Wire cross-section, max. 2.5 mm² Wire cross-section AWG, min. 16 Wire cross-section AWG, max. 14 Materials Connector material Copper Surface Tin-plated insul. Expanded PA insulation Working temperature, min. -55 °C Working temperature, max. 105 °C Further technical data Insulation available Soldered Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 10:43:30 Subject to technical changes 2 Data sheet 3068.0 QKS G 2,5 Approvals Standards and regulations Standards / specifications Creation date 15.12.2023 10:43:30 DIN EN 13599 Subject to technical changes 3 Data sheet 3068.0 QKS G 2,5 Media Creation date 15.12.2023 10:43:30 Subject to technical changes 4 Data sheet 3068.0 QKS G 2,5 Accessories Creation date 15.12.2023 10:43:30 Subject to technical changes 5
3068.0 价格&库存
很抱歉,暂时无法提供与“3068.0”相匹配的价格&库存,您可以联系我们找货
