3081.0
3081.0
    CONTA-CLIP
    FERRULES
3081.0 数据手册
Data sheet 3081.0 H 2,5/14-D SR BU Wire-end ferrules, Max. wire cross-section: 2.5 mm², Length: 14 mm, Length of copper pipe: 8 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3081.0 Article name H 2,5/14-D SR BU GTIN (EAN) 4044211057862 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.13 g Weight per piece (including packaging) 0.14 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour Blue Creation date 14.12.2023 19:56:50 Subject to technical changes 1 Data sheet 3081.0 H 2,5/14-D SR BU Technical data Dimensions Length 14 mm Length of copper pipe 8 mm Diameter of copper pipe 2.2 mm Diameter plastic collar 4 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.25 mm Connection data Wire cross-section, max. 2.5 mm² Wire cross-section AWG, max. 14 Stripping length 8 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 14.12.2023 19:56:50 Subject to technical changes 2 Data sheet 3081.0 H 2,5/14-D SR BU Approvals Standards and regulations DIN 46228-4:1990 Creation date 14.12.2023 19:56:50 yes Subject to technical changes 3 Data sheet 3081.0 H 2,5/14-D SR BU Media Creation date 14.12.2023 19:56:50 Subject to technical changes 4 Data sheet 3081.0 H 2,5/14-D SR BU Accessories Creation date 14.12.2023 19:56:50 Subject to technical changes 5
3081.0 价格&库存
很抱歉,暂时无法提供与“3081.0”相匹配的价格&库存,您可以联系我们找货
