3090.0
3090.0
    CONTA-CLIP
    FERRULES
3090.0 数据手册
Data sheet 3090.0 H 0,5/8-D AWG WH Wire-end ferrules, Max. wire cross-section: 0.5 mm², Length: 14 mm, Length of copper pipe: 8 mm, Colour: White RAL: 9010 Business data Article number 3090.0 Article name H 0,5/8-D AWG WH GTIN (EAN) 4044211057954 Packaging unit 500 Quantity unit PC Weight per piece (not including packaging) 0.08 g Weight per piece (including packaging) 0.09 g Unit of weight G Customs number 85369010 Country of origin DE Product description Ferrules Colour White Creation date 15.12.2023 08:49:25 Subject to technical changes 1 Data sheet 3090.0 H 0,5/8-D AWG WH Technical data Dimensions Length 14 mm Length of copper pipe 8 mm Diameter of copper pipe 1.1 mm Diameter plastic collar 2.9 mm Wall thickness of copper pipe 0.15 mm Wall thickness of plastic collar 0.25 mm Connection data Wire cross-section, max. 0.5 mm² Wire cross-section AWG, max. 20 Stripping length 10 mm Materials Copper pipe Copper alloy Surface Galvanically tin-plated, shiny Plastic collar Polypropylene homopolymer Working temperature, min. -5 °C Working temperature, max. 105 °C Further technical data Insulation available Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 08:49:25 Subject to technical changes 2 Data sheet 3090.0 H 0,5/8-D AWG WH Approvals Standards and regulations DIN 46228-4:1990 Creation date 15.12.2023 08:49:25 yes Subject to technical changes 3 Data sheet 3090.0 H 0,5/8-D AWG WH Media Creation date 15.12.2023 08:49:25 Subject to technical changes 4 Data sheet 3090.0 H 0,5/8-D AWG WH Accessories Creation date 15.12.2023 08:49:25 Subject to technical changes 5
3090.0 价格&库存
很抱歉,暂时无法提供与“3090.0”相匹配的价格&库存,您可以联系我们找货
