3204.2
    CONTA-CLIP
    EARTH TERMINAL
3204.2 数据手册
Data sheet 3204.2 FSL 1,5/3A GNYE Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Green-yellow Business data Article number 3204.2 Article name FSL 1,5/3A GNYE GTIN (EAN) 4044211110116 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 9.6 g Weight per piece (including packaging) 10.1 g Unit of weight G Customs number 85369010 Country of origin BG Product description Protective earth terminal Colour Green-yellow Creation date 17.12.2023 08:40:58 Subject to technical changes 1 Data sheet 3204.2 FSL 1,5/3A GNYE Technical data Dimensions Length 59.5 mm Width 4.1 mm Height 42.3 mm Height TS 35/7.5 43 mm Ratings Rated cross-section 1.5 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Push-in connection Connection position Top Connections 3 Number of terminals per level 3 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 1.5 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 1.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 1.5 mm² Wire cross-section AWG, min. 24 Wire cross-section AWG, max. 16 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 08:40:58 Subject to technical changes 2 Data sheet 3204.2 FSL 1,5/3A GNYE Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A1 Number of cross-connection channels 2 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 08:40:58 Subject to technical changes 3 Data sheet 3204.2 FSL 1,5/3A GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA wire cross-section AWG, min. 24 CSA wire cross-section AWG, max. 16 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus wire cross-section AWG, min. 24 CSAus wire cross-section AWG, max. 16 CSAus stripping length 12 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 1.5 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 1.5 mm² Creation date 17.12.2023 08:40:58 Subject to technical changes 4 Data sheet 3204.2 FSL 1,5/3A GNYE Media Creation date 17.12.2023 08:40:58 Subject to technical changes 5 Data sheet 3204.2 FSL 1,5/3A GNYE Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3401.2 FAP 1,5/3A BG 4044211112608 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 4 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4820.7 PMC SB 4/50 WH 4044211112127 500 ST Screwdriver Screwdriver with bare blade, Colour: Article number Article name GTIN (EAN) Packaging unit 3164.0 SDB 0,4x2,0 4044211107246 1 ST Four-way cover Creation date 17.12.2023 08:40:58 Subject to technical changes 6 Data sheet 3204.2 FSL 1,5/3A GNYE Cover, Length: 3.4 mm, Width: 15.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3425.8 FAD 1,5/4/B YE 4044211132910 20 ST Creation date 17.12.2023 08:40:58 Subject to technical changes 7
3204.2 价格&库存
很抱歉,暂时无法提供与“3204.2”相匹配的价格&库存,您可以联系我们找货
