Data sheet
3210.3 FRK 2,5/2A OG
Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5
mm², Width: 5.1 mm, Colour: Orange
Business data
Article number
3210.3
Article name
FRK 2,5/2A OG
GTIN (EAN)
4044211109790
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
8g
Weight per piece (including packaging)
8.5 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Prio-Article
3210.2
Product description
Creation date 17.12.2023 08:39:11
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
48.5 mm
Width
5.1 mm
Height
42.3 mm
Height TS 35/7.5
43 mm
Ratings
Rated voltage
800 V
Rated current
24 A
Rated cross-section
2.5 mm²
Rated impulse voltage
8 kV
Overvoltage category
III
Contamination degree
3
Maximum power dissipation for nominal condition
0.77 W
Connection data
Connection principle
Push-in connection
Connection position
Top
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
4 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
4 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
2.5 mm²
Wire cross-section AWG, min.
26
Wire cross-section AWG, max.
12
Stripping length
12 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A3
Number of cross-connection channels
2
End plate required
Environmental Product Compliance
REACH Conform
Yes
REACH Candidate Substance Note
No
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA Usegroup C: rated voltage
600 V
CSA Usegroup C: rated current
21 A
CSA wire cross-section AWG, min.
26
CSA wire cross-section AWG, max.
12
CSA stripping length
12 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus Usegroup C: rated voltage
600 V
CSAus Usegroup C: rated current
21 A
CSAus wire cross-section AWG, min.
26
CSAus wire cross-section AWG, max.
12
CSAus stripping length
12 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-1:2009
KEMA KEUR approval granted
yes
KEMA rated voltage
800 V
KEMA rated current
24 A
KEMA rated impulse voltage
8 kV
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
4 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
4 mm²
4
Data sheet
Media
5
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3400.2
FAP 1,5-4/2A BG
4044211110208
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3811.2
ZES 35/2 BG
4044211080600
50
Insulated cross-connector
Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 40.7 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3468.8
FQI 2,5/8 YE
4044211110796
10
Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 45.8 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3469.8
FQI 2,5/9 YE
4044211110802
10
Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 35.6 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3467.8
FQI 2,5/7 YE
4044211110789
6
Data sheet
Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 20.3 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3464.8
FQI 2,5/4 YE
4044211110758
Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 25.4 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3465.8
FQI 2,5/5 YE
4044211110765
Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 30.5 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3466.8
FQI 2,5/6 YE
4044211110772
Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.9 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3460.8
FQI 2,5/10 YE
4044211110727
10
Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 15.2 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3463.8
FQI 2,5/3 YE
4044211110741
50
Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.1 mm,
Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3462.8
FQI 2,5/2 YE
4044211110734
50
7
Data sheet
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4600.7
PMC SB 5/50 WH
4044211088903
500 ST
Four-way cover
Cover, Length: 3.4 mm, Width: 19.8 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3426.8
FAD 2,5/4/B YE
4044211132934
20 ST
8
