3210.5
3210.5
    CONTA-CLIP
    FEED-THROUGH TERMINAL
3210.5 数据手册
Data sheet 3210.5 FRK 2,5/2A BU Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3210.5 Article name FRK 2,5/2A BU GTIN (EAN) 4044211109752 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 8g Weight per piece (including packaging) 8.5 g Unit of weight G Customs number 85369010 Country of origin BG Prio-Article 3210.2 Product description Feed-through terminal Creation date 15.12.2023 18:50:23 Subject to technical changes 1 Data sheet 3210.5 FRK 2,5/2A BU Technical data Dimensions Length 48.5 mm Width 5.1 mm Height 42.3 mm Height TS 35/7.5 43 mm Ratings Rated voltage 800 V Rated current 24 A Rated cross-section 2.5 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.77 W Connection data Connection principle Push-in connection Connection position Top Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 4 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 26 Wire cross-section AWG, max. 12 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 18:50:23 Subject to technical changes 2 Data sheet 3210.5 FRK 2,5/2A BU Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 2 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 15.12.2023 18:50:23 No Subject to technical changes 3 Data sheet 3210.5 FRK 2,5/2A BU Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 21 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 12 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 21 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 12 CSAus stripping length 12 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 24 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² Creation date 15.12.2023 18:50:23 Subject to technical changes 4 Data sheet 3210.5 FRK 2,5/2A BU Media Creation date 15.12.2023 18:50:23 Subject to technical changes 5 Data sheet 3210.5 FRK 2,5/2A BU Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3400.2 FAP 1,5-4/2A BG 4044211110208 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Insulated cross-connector Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 40.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3468.8 FQI 2,5/8 YE 4044211110796 10 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 45.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3469.8 FQI 2,5/9 YE 4044211110802 10 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 35.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3467.8 FQI 2,5/7 YE 4044211110789 20 Creation date 15.12.2023 18:50:23 Subject to technical changes 6 Data sheet 3210.5 FRK 2,5/2A BU Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 20.3 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3464.8 FQI 2,5/4 YE 4044211110758 20 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 25.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3465.8 FQI 2,5/5 YE 4044211110765 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 30.5 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3466.8 FQI 2,5/6 YE 4044211110772 20 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3460.8 FQI 2,5/10 YE 4044211110727 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 15.2 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3463.8 FQI 2,5/3 YE 4044211110741 50 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 10.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3462.8 FQI 2,5/2 YE 4044211110734 50 Creation date 15.12.2023 18:50:23 Subject to technical changes 7 Data sheet 3210.5 FRK 2,5/2A BU Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 3.4 mm, Width: 19.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3426.8 FAD 2,5/4/B YE 4044211132934 20 ST Creation date 15.12.2023 18:50:23 Subject to technical changes 8
3210.5 价格&库存
很抱歉,暂时无法提供与“3210.5”相匹配的价格&库存,您可以联系我们找货
  • 100+11.26187100+1.41226
