3221.1
3221.1
    CONTA-CLIP
    FEED-THROUGH TERMINAL
3221.1 数据手册
Data sheet 3221.1 FRK 4/3A GN Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green Business data Article number 3221.1 Article name FRK 4/3A GN GTIN (EAN) 4044211110017 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 13.4 g Weight per piece (including packaging) 14.17 g Unit of weight G Customs number 85369010 Country of origin BG Prio-Article 3221.2 Product description Feed-through terminal Creation date 17.12.2023 08:41:26 Subject to technical changes 1 Data sheet 3221.1 FRK 4/3A GN Technical data Dimensions Length 64.3 mm Width 6.1 mm Height 42.3 mm Height TS 35/7.5 43 mm Ratings Rated voltage 800 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Push-in connection Connection position Top Connections 3 Number of terminals per level 3 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 08:41:26 Subject to technical changes 2 Data sheet 3221.1 FRK 4/3A GN Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 2 End plate required Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 08:41:26 Subject to technical changes 3 Data sheet 3221.1 FRK 4/3A GN Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 35 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 35 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 10 CSAus stripping length 12 mm KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 6 mm² Creation date 17.12.2023 08:41:26 Subject to technical changes 4 Data sheet 3221.1 FRK 4/3A GN Media Creation date 17.12.2023 08:41:26 Subject to technical changes 5 Data sheet 3221.1 FRK 4/3A GN Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3421.2 FAP 4/3A BG 4044211110529 20 End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 24.3 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3474.8 FQI 4/4 YE 4044211110840 20 Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 30.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3475.8 FQI 4/5 YE 4044211110857 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 36.5 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3476.8 FQI 4/6 YE 4044211110864 20 Creation date 17.12.2023 08:41:26 Subject to technical changes 6 Data sheet 3221.1 FRK 4/3A GN Insulated cross-connector Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 60.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3470.8 FQI 4/10 YE 4044211110819 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 18.2 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3473.8 FQI 4/3 YE 4044211110833 50 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 12.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3472.8 FQI 4/2 YE 4044211110826 50 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 42.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3477.8 FQI 4/7 YE 4044211110871 20 Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 54.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3479.8 FQI 4/9 YE 4044211110895 10 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 48.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3478.8 FQI 4/8 YE 4044211110888 10 Creation date 17.12.2023 08:41:26 Subject to technical changes 7 Data sheet 3221.1 FRK 4/3A GN Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Four-way cover Cover, Length: 3.8 mm, Width: 23.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3427.8 FAD 4/4/B YE 4044211132941 20 ST Creation date 17.12.2023 08:41:26 Subject to technical changes 8
3221.1 价格&库存
很抱歉,暂时无法提供与“3221.1”相匹配的价格&库存,您可以联系我们找货
