Data sheet
3223.2 FSL 4/2A GNYE
Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4
mm², Width: 6.1 mm, Colour: Green-yellow
Business data
Article number
3223.2
Article name
FSL 4/2A GNYE
GTIN (EAN)
4044211110161
Packaging unit
100
Quantity unit
PC
Weight per piece (not including packaging)
12.2 g
Weight per piece (including packaging)
12.94 g
Unit of weight
G
Customs number
85369010
Country of origin
BG
Product description
Colour
Green-yellow
Creation date 16.12.2023 11:46:51
Subject to technical changes
1
Data sheet
Technical data
Dimensions
Length
48.5 mm
Width
6.1 mm
Height
42.3 mm
Height TS 35/7.5
43 mm
Ratings
Rated cross-section
4 mm²
Overvoltage category
III
Contamination degree
3
Connection data
Connection principle
Push-in connection
Connection position
Top
Connections
2
Number of terminals per level
2
Number of levels
1
Wire cross-section single-core (rigid) / stranded, min.
0.2 mm²
Wire cross-section single core (rigid)/stranded, max.
6 mm²
Wire cross-section stranded, min.
0.2 mm²
Wire cross-section stranded, max.
6 mm²
Wire cross-section stranded with wire-end ferrules,
min.
0.2 mm²
max.
4 mm²
Wire cross-section AWG, min.
Wire cross-section AWG, max.
10
Stripping length
12 mm
Materials
Insulation housing
Polyamide 6.6
Flammability class UL 94
V-0
Working temperature, min.
-40 °C
Working temperature, max.
120 °C
2
Data sheet
Technical data
Further technical data
Mounting type
Mounting rail TS 35/7,5
Gauge plug acc. to EN 60 947-1
A4
Number of cross-connection channels
2
End plate required
Environmental Product Compliance
REACH Conform
yes
REACH Reference date
2023-06-14
REACH Candidate Substance Note
No
RoHS Conform
yes
3
Data sheet
Approvals
Standards and regulations
EAC approval
TR ZU 004/2011
EAC approval granted
yes
CSA approval
CSA approval
C22.2 No 158
CSA approval granted
yes
CSA wire cross-section AWG, min.
26
CSA wire cross-section AWG, max.
10
CSA stripping length
12 mm
CSAus approval
CSAus approval
UL 1059
CSAus approval granted
yes
CSAus wire cross-section AWG, min.
26
CSAus wire cross-section AWG, max.
10
CSAus stripping length
12 mm
KEMA KEUR approval
KEMA KEUR approval
EN 60947-7-2:2009
KEMA KEUR approval granted
yes
KEMA wire cross-section single core (rigid), min.
0.2 mm²
KEMA wire cross-section single-core (rigid), max.
6 mm²
KEMA wire cross-section stranded, min.
0.2 mm²
KEMA wire cross-section stranded, max.
6 mm²
4
Data sheet
Media
5
Data sheet
Accessories
End plate
End plate, Width: 1.5 mm, Colour: Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3400.2
FAP 1,5-4/2A BG
4044211110208
End stop
End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour:
Beige
Article number
Article name
GTIN (EAN)
Packaging
unit
3811.2
ZES 35/2 BG
4044211080600
50
Quick marking
Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White
Article number
Article name
GTIN (EAN)
Packaging
unit
4702.7
PMC SB 6/50 WH
4044211089986
500 ST
Screwdriver
Screwdriver with bare blade, Colour: Black-grey
Article number
Article name
GTIN (EAN)
Packaging
unit
1086.0
SDB 0,6x3,5
4044211014797
1 ST
Four-way cover
6
Data sheet
Cover, Length: 3.8 mm, Width: 23.6 mm, Colour: Yellow
Article number
Article name
GTIN (EAN)
Packaging
unit
3427.8
FAD 4/4/B YE
4044211132941
20 ST
7
很抱歉,暂时无法提供与“3223.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+41.66464100+5.38758
