3276.2
3276.2
    CONTA-CLIP
    FEED-THROUGH INSTALLATION TERMIN
3276.2 数据手册
Data sheet 3276.2 FRKI 2,5-4 BG Feed-through installation terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated crosssection: 4 mm², Width: 5.1 mm, Colour: Beige Business data Article number 3276.2 Article name FRKI 2,5-4 BG GTIN (EAN) 4044211139001 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 8g Weight per piece (including packaging) 8.25 g Unit of weight G Customs number 85369010 Country of origin BG Prio-Article 3276.2 Product description Feed-through installation terminal Creation date 16.12.2023 21:32:28 Subject to technical changes 1 Data sheet 3276.2 FRKI 2,5-4 BG Technical data Dimensions Length 52.5 mm Width 5.1 mm Height 37.5 mm Height TS 35/7.5 38.5 mm Ratings Rated voltage 800 V Rated current 32 A Rated cross-section 4 mm² Rated impulse voltage 8 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 1.02 W Connection data Connection principle Push-in connection Connection position Top Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.6 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 16.12.2023 21:32:28 Subject to technical changes 2 Data sheet 3276.2 FRKI 2,5-4 BG Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 2 End plate required Environmental Product Compliance REACH Candidate Substance Note Creation date 16.12.2023 21:32:28 No Subject to technical changes 3 Data sheet 3276.2 FRKI 2,5-4 BG Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 600 V CSA Usegroup C: rated current 28 A CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 600 V CSAus Usegroup C: rated current 28 A CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 10 CSAus stripping length 12 mm cUL Recognized cUL approval C22.2 No 158 cUL Usegroup B: rated voltage 600 V cUL Usegroup B: rated current 28 A cUL Usegroup C: rated voltage 600 V cUL Usegroup C: rated current 28 A cUL Usegroup D: rated voltage 600 V cUL Usegroup D: rated current 28 A cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 10 cUL wire material Cu cUL Recognized 1 Creation date 16.12.2023 21:32:28 Subject to technical changes 4 Data sheet 3276.2 FRKI 2,5-4 BG Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-1:2009 KEMA KEUR approval granted yes KEMA rated voltage 800 V KEMA rated current 32 A KEMA rated impulse voltage 8 kV KEMA wire cross-section single core (rigid), min. 0.08 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.08 mm² KEMA wire cross-section stranded, max. 6 mm² UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 600 V UL Usegroup B: rated current 28 A UL Usegroup C: rated voltage 600 V UL Usegroup C: rated current 28 A UL Usegroup D: rated voltage 600 V UL Usegroup D: rated current 28 A UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 10 UL wire cross-section stranded AWG, max. 26 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 16.12.2023 21:32:28 Subject to technical changes 5 Data sheet 3276.2 FRKI 2,5-4 BG Media Creation date 16.12.2023 21:32:28 Subject to technical changes 6 Data sheet 3276.2 FRKI 2,5-4 BG Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3484.2 FAPI 2,5-4/2A BG 4044211176402 20 Wire-end ferrule for compact connection spaces Wire-end ferrules, Max. wire cross-section: 4 mm², Length: 20 mm, Length of copper pipe: 12 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3194.0 H 4,0/20-D SR GR 4044211134280 500 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Insulated cross-connector Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 30 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17406.8 FIQI 2,5-4/6 YE 4044211175993 20 ST Creation date 16.12.2023 21:32:28 Subject to technical changes 7 Data sheet 3276.2 FRKI 2,5-4 BG Insulated cross-connector Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 45.3 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17409.8 FIQI 2,5-4/9 YE 4044211176020 10 ST Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 50.4 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17400.8 FIQI 2,5-4/10 YE 4044211175948 10 ST Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 14.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17403.8 FIQI 2,5-4/3 YE 4044211175962 50 ST Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 40.2 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17408.8 FIQI 2,5-4/8 YE 4044211176013 10 ST Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 9.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17402.8 FIQI 2,5-4/2 YE 4044211175955 50 ST Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 35.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17407.8 FIQI 2,5-4/7 YE 4044211176006 20 ST Creation date 16.12.2023 21:32:28 Subject to technical changes 8 Data sheet 3276.2 FRKI 2,5-4 BG Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 19.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17404.8 FIQI 2,5-4/4 YE 4044211175979 20 ST Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 24.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 17405.8 FIQI 2,5-4/5 YE 4044211175986 20 ST Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Four-way cover Cover, Length: 3.4 mm, Width: 19.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3426.8 FAD 2,5/4/B YE 4044211132934 20 ST Test adapters Test adapter, Pitch size: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3428.2 FTA 2,5-4/1 BG 4044211190231 10 ST Creation date 16.12.2023 21:32:28 Subject to technical changes 9
3276.2 价格&库存
很抱歉,暂时无法提供与“3276.2”相匹配的价格&库存,您可以联系我们找货
