3293.4
3293.4
    CONTA-CLIP
    FUSE DISCONNECT TERMINAL
3293.4 数据手册
Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Fuse-disconnect terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6 mm, Colour: Black RAL: 9005 Business data Article number 3293.4 Article name FSIK 4/2A/LED 110-250V AC/DC BK GTIN (EAN) 4044211188986 Packaging unit 25 Quantity unit PC Weight per piece (not including packaging) 87.56 g Weight per piece (including packaging) 87.66 g Unit of weight G Customs number 85369010 Country of origin DE Product description Fuse-disconnect terminal Colour Black Creation date 15.12.2023 11:25:33 Subject to technical changes 1 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Technical data Dimensions Length 67.5 mm Width 6.1 mm Height 69 mm Height TS 35/7.5 70 mm Ratings Rated voltage (determined by the illuminated display and fuse being used) 250 V Rated current 6.3 A Rated cross-section 4 mm² Rated impulse voltage 6 kV Overvoltage category III Contamination degree 3 Maximum power dissipation for nominal condition 0.2 W Connection data Connection principle Push-in connection Connection position Top Connections 2 / extraction lever Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.2 mm² Wire cross-section single core (rigid)/stranded, max. 4 mm² Wire cross-section stranded, min. 0.2 mm² Wire cross-section stranded, max. 2.5 mm² Wire cross-section stranded with wire-end ferrules, min. 0.2 mm² Wire cross-section stranded with wire-end ferrules, max. 2.5 mm² Wire cross-section AWG, min. 24 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 15.12.2023 11:25:33 Subject to technical changes 2 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Fuse size 5 x 20 mm Gauge plug acc. to EN 60 947-1 A3 Number of cross-connection channels 1 End plate required Voltage fuse 250 V Voltage illuminated display 110-250 V Cross-current via illuminated display 5 mA Power loss in singular arrangement - overload and short-circuit protection, max. 4 /6,3 W / A Power loss in compound arrangement - overload and short-circuit protection, max. 1,6 / 6,3 W / A Power loss in singular arrangement - only short-circuit protection, max. 4 / 10 W / A Power loss in compound arrangement - only short-circuit protection, max. 4 / 6,3 W / A Version of fuse holder Swivelling Type of display element (defect display) LED Version of fuse cartridge G fuse 5 x 20 Supply voltage (defect display), min. 110 Supply voltage (defect display), max. 250 Type of voltage (defect display) AC/DC Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 15.12.2023 11:25:33 Subject to technical changes 3 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Approvals CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA Usegroup C: rated voltage 300 V CSA Usegroup C: rated current 6,3 A CSA wire cross-section AWG, min. 24 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus Usegroup C: rated voltage 300 V CSAus Usegroup C: rated current 6,3 A CSAus wire cross-section AWG, min. 24 CSAus wire cross-section AWG, max. 10 CSAus stripping length 12 mm Creation date 15.12.2023 11:25:33 Subject to technical changes 4 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Approvals KEMA KEUR approval KEMA KEUR approval EN 60947-7-3:2009 KEMA KEUR approval granted yes KEMA rated voltage 250 V KEMA voltage fuse, max. 250 V KEMA rated current 6,3 A KEMA rated impulse voltage (fuse holder withoutelectrical components) 6 (4) kV KEMA wire cross-section single core (rigid), min. 0.2 mm² KEMA wire cross-section single-core (rigid), max. 4 mm² KEMA wire cross-section stranded, min. 0.2 mm² KEMA wire cross-section stranded, max. 4 mm² KEMA fuse size 5 x 20 mm KEMA power loss in singular arrangement - overloadand short-circuit protection, max. 4 /6,3 W / A KEMA power loss in compound arrangement -overload and short-circuit protection, max. 1,6 / 6,3 W / A KEMA power loss in singular arrangement - only short-circuit protection, max. 4 / 10 W / A KEMA power loss in compound arrangement - onlyshort-circuit protection, max. 4 / 6,3 W / A UL Recognized UL approval UL 1059 UL Usegroup B: rated voltage 300 V UL Usegroup B: rated current 6,3 A UL Usegroup C: rated voltage 300 V UL Usegroup C: rated current 6,3 A UL Usegroup D: rated voltage 300 V UL Usegroup D: rated current 6,3 A UL wire cross-section single-core (rigid) AWG, min. 24 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 24 UL wire cross-section stranded AWG, max. 10 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 15.12.2023 11:25:33 Subject to technical changes 5 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Media Creation date 15.12.2023 11:25:33 Subject to technical changes 6 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Accessories End plate End plate, Width: 1.5 mm, Colour: Black Article number Article name GTIN (EAN) Packaging unit 3489.4 FAPSI 4/2A BK 4044211184681 20 Wire-end ferrule for compact connection spaces Wire-end ferrules, Max. wire cross-section: 4 mm², Length: 20 mm, Length of copper pipe: 12 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3194.0 H 4,0/20-D SR GR 4044211134280 500 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Insulated cross-connector Insulated cross-connector, No. of poles: 4, Mounting type: Plug in, Width: 24.3 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3474.8 FQI 4/4 YE 4044211110840 20 Creation date 15.12.2023 11:25:33 Subject to technical changes 7 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Insulated cross-connector Insulated cross-connector, No. of poles: 5, Mounting type: Plug in, Width: 30.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3475.8 FQI 4/5 YE 4044211110857 20 Insulated cross-connector, No. of poles: 6, Mounting type: Plug in, Width: 36.5 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3476.8 FQI 4/6 YE 4044211110864 20 Insulated cross-connector, No. of poles: 10, Mounting type: Plug in, Width: 60.9 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3470.8 FQI 4/10 YE 4044211110819 10 Insulated cross-connector, No. of poles: 3, Mounting type: Plug in, Width: 18.2 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3473.8 FQI 4/3 YE 4044211110833 50 Insulated cross-connector, No. of poles: 2, Mounting type: Plug in, Width: 12.1 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3472.8 FQI 4/2 YE 4044211110826 50 Insulated cross-connector, No. of poles: 7, Mounting type: Plug in, Width: 42.6 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3477.8 FQI 4/7 YE 4044211110871 20 Creation date 15.12.2023 11:25:33 Subject to technical changes 8 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Insulated cross-connector Insulated cross-connector, No. of poles: 9, Mounting type: Plug in, Width: 54.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3479.8 FQI 4/9 YE 4044211110895 10 Insulated cross-connector, No. of poles: 8, Mounting type: Plug in, Width: 48.7 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3478.8 FQI 4/8 YE 4044211110888 10 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 6 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4702.7 PMC SB 6/50 WH 4044211089986 500 ST Screwdriver Screwdriver with bare blade, Colour: Article number Article name GTIN (EAN) Packaging unit 3164.0 SDB 0,4x2,0 4044211107246 1 ST Connecting sleeve Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2873.3 VBS 2/10 OG 4044211055981 20 ST Creation date 15.12.2023 11:25:33 Subject to technical changes 9 Data sheet 3293.4 FSIK 4/2A/LED 110-250V AC/DC BK Connecting sleeve Connecting sleeve, Colour: Orange Article number Article name GTIN (EAN) Packaging unit 2874.3 VBS 3/10 OG 4044211055998 20 ST Creation date 15.12.2023 11:25:33 Subject to technical changes 10
3293.4 价格&库存
很抱歉,暂时无法提供与“3293.4”相匹配的价格&库存,您可以联系我们找货
