3279.2
    CONTA-CLIP
    EARTH INSTALLATION TERMINAL
3279.2 数据手册
Data sheet 3279.2 FSLI 2,5-4 GNYE PE installation terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 5.1 mm, Colour: Green-yellow Business data Article number 3279.2 Article name FSLI 2,5-4 GNYE GTIN (EAN) 4044211139094 Packaging unit 100 Quantity unit PC Weight per piece (not including packaging) 11 g Weight per piece (including packaging) 11.25 g Unit of weight G Customs number 85369010 Country of origin BG Product description PE installation terminal Colour Green-yellow Creation date 17.12.2023 08:41:54 Subject to technical changes 1 Data sheet 3279.2 FSLI 2,5-4 GNYE Technical data Dimensions Length 52.5 mm Width 5.1 mm Height 37.5 mm Height TS 35/7.5 38.5 mm Ratings Rated cross-section 4 mm² Overvoltage category III Contamination degree 3 Connection data Connection principle Push-in connection Connection position Top Connections 2 Number of terminals per level 2 Number of levels 1 Wire cross-section single-core (rigid) / stranded, min. 0.5 mm² Wire cross-section single core (rigid)/stranded, max. 6 mm² Wire cross-section stranded, min. 0.6 mm² Wire cross-section stranded, max. 6 mm² Wire cross-section stranded with wire-end ferrules, min. 0.5 mm² Wire cross-section stranded with wire-end ferrules, max. 4 mm² Wire cross-section AWG, min. 20 Wire cross-section AWG, max. 10 Stripping length 12 mm Materials Insulation housing Polyamide 6.6 Flammability class UL 94 V-0 Working temperature, min. -40 °C Working temperature, max. 120 °C Creation date 17.12.2023 08:41:54 Subject to technical changes 2 Data sheet 3279.2 FSLI 2,5-4 GNYE Technical data Further technical data Mounting type Mounting rail TS 35/7,5 Gauge plug acc. to EN 60 947-1 A4 Number of cross-connection channels 1 End plate required Environmental Product Compliance REACH Conform yes REACH Reference date 2023-06-14 REACH Candidate Substance Note No RoHS Conform yes Creation date 17.12.2023 08:41:54 Subject to technical changes 3 Data sheet 3279.2 FSLI 2,5-4 GNYE Approvals Standards and regulations EAC approval TR ZU 004/2011 EAC approval granted yes CSA approval CSA approval C22.2 No 158 CSA approval granted yes CSA wire cross-section AWG, min. 26 CSA wire cross-section AWG, max. 10 CSA stripping length 12 mm CSAus approval CSAus approval UL 1059 CSAus approval granted yes CSAus wire cross-section AWG, min. 26 CSAus wire cross-section AWG, max. 10 CSAus stripping length 12 mm cUL Recognized cUL approval C22.2 No 158 cUL wire cross-section single-core (rigid) AWG, min. 26 cUL wire cross-section single-core (rigid) AWG, max. 10 cUL wire cross-section stranded AWG, min. 26 cUL wire cross-section stranded AWG, max. 10 cUL wire material Cu cUL Recognized 1 KEMA KEUR approval KEMA KEUR approval EN 60947-7-2:2009 KEMA KEUR approval granted yes KEMA wire cross-section single core (rigid), min. 0.08 mm² KEMA wire cross-section single-core (rigid), max. 6 mm² KEMA wire cross-section stranded, min. 0.08 mm² KEMA wire cross-section stranded, max. 6 mm² Creation date 17.12.2023 08:41:54 Subject to technical changes 4 Data sheet 3279.2 FSLI 2,5-4 GNYE Approvals UL Recognized UL approval UL 1059 UL wire cross-section single-core (rigid) AWG, min. 26 UL wire cross-section single-core (rigid) AWG, max. 10 UL wire cross-section stranded AWG, min. 26 UL wire cross-section stranded AWG, max. 10 UL wire material Cu UL factory wiring 1 UL field wiring 1 UL Recognized 1 Creation date 17.12.2023 08:41:54 Subject to technical changes 5 Data sheet 3279.2 FSLI 2,5-4 GNYE Media Creation date 17.12.2023 08:41:54 Subject to technical changes 6 Data sheet 3279.2 FSLI 2,5-4 GNYE Accessories End plate End plate, Width: 1.5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3484.2 FAPI 2,5-4/2A BG 4044211176402 20 Wire-end ferrule for compact connection spaces Wire-end ferrules, Max. wire cross-section: 4 mm², Length: 20 mm, Length of copper pipe: 12 mm, Colour: Grey Article number Article name GTIN (EAN) Packaging unit 3194.0 H 4,0/20-D SR GR 4044211134280 500 ST End stop End stop, Mounting type: Mounting rail TS 35/7.5 and TS 35/15, Width: 5 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3811.2 ZES 35/2 BG 4044211080600 50 Quick marking Terminal marker / Pocket Maxicard, Length: 5 mm, Width: 5 mm, Colour: White Article number Article name GTIN (EAN) Packaging unit 4600.7 PMC SB 5/50 WH 4044211088903 500 ST Screwdriver Creation date 17.12.2023 08:41:54 Subject to technical changes 7 Data sheet 3279.2 FSLI 2,5-4 GNYE Screwdriver with bare blade, Colour: Article number Article name GTIN (EAN) Packaging unit 3164.0 SDB 0,4x2,0 4044211107246 1 ST Four-way cover Cover, Length: 3.4 mm, Width: 19.8 mm, Colour: Yellow Article number Article name GTIN (EAN) Packaging unit 3426.8 FAD 2,5/4/B YE 4044211132934 20 ST Creation date 17.12.2023 08:41:54 Subject to technical changes 8
3279.2 价格&库存
很抱歉,暂时无法提供与“3279.2”相匹配的价格&库存,您可以联系我们找货
