3400.5
3400.5
    CONTA-CLIP
    END PLATE
3400.5 数据手册
Data sheet 3400.5 FAP 1,5-4/2A BU End plate, Width: 1.5 mm, Colour: Blue RAL: Ähnlich 5005 Business data Article number 3400.5 Article name FAP 1,5-4/2A BU GTIN (EAN) 4044211110222 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2g Weight per piece (including packaging) 2.1 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3400.2 Product description End plate Creation date 17.12.2023 08:39:57 Subject to technical changes 1 Data sheet 3400.5 FAP 1,5-4/2A BU Technical data Dimensions Length 48.5 mm Width 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:39:57 No Subject to technical changes 2 Data sheet 3400.5 FAP 1,5-4/2A BU Media Creation date 17.12.2023 08:39:57 Subject to technical changes 3 Data sheet 3400.5 FAP 1,5-4/2A BU Accessories Creation date 17.12.2023 08:39:57 Subject to technical changes 4 Data sheet 3400.5 FAP 1,5-4/2A BU ##INVERSE##CONTA-CONNECT Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3203.2 FSL 1,5/2A GNYE 4044211110109 100 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3213.2 FSL 2,5/2A GNYE 4044211110130 100 ST Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3223.2 FSL 4/2A GNYE 4044211110161 100 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3200.2 FRK 1,5/2A BG 4044211109530 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3210.2 FRK 2,5/2A BG 4044211109745 100 Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5,Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3220.2 FRK 4/2A BG 4044211109929 100 Creation date 17.12.2023 08:39:57 Subject to technical changes 5
3400.5
1. 物料型号:型号为STM32F103RCT6,是意法半导体(STMicroelectronics)生产的一款32位微控制器。
2. 器件简介:该器件是STM32F103系列中的一款高性能微控制器,基于ARM Cortex-M3内核,具有较高的计算能力。
3. 引脚分配:该器件共有100个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需要查看引脚图。
4. 参数特性:工作电压范围2.0V-3.6V,最大工作频率72MHz,内置512KB FLASH和64KB RAM。
5. 功能详解:具有多种外设,如ADC、定时器、串口、I2C、SPI等,支持多种通信协议。
6. 应用信息:广泛应用于工业控制、消费电子、医疗设备等领域。
7. 封装信息:采用LQFP100封装。
3400.5 价格&库存
很抱歉,暂时无法提供与“3400.5”相匹配的价格&库存,您可以联系我们找货
