3401.2
3401.2
    CONTA-CLIP
    END PLATE
3401.2 数据手册
Data sheet 3401.2 FAP 1,5/3A BG End plate, Width: 1.5 mm, Colour: Beige Business data Article number 3401.2 Article name FAP 1,5/3A BG GTIN (EAN) 4044211112608 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.4 g Weight per piece (including packaging) 2.5 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3401.2 Product description End plate Creation date 17.12.2023 08:40:13 Subject to technical changes 1 Data sheet 3401.2 FAP 1,5/3A BG Technical data Dimensions Length 59.8 mm Width 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 08:40:13 Subject to technical changes 2 Data sheet 3401.2 FAP 1,5/3A BG Media Creation date 17.12.2023 08:40:13 Subject to technical changes 3 Data sheet 3401.2 FAP 1,5/3A BG Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3204.2 FSL 1,5/3A GNYE 4044211110116 100 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 1.5 mm², Width: 4.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3201.2 FRK 1,5/3A BG 4044211109615 100 Creation date 17.12.2023 08:40:13 Subject to technical changes 4
3401.2 价格&库存
很抱歉,暂时无法提供与“3401.2”相匹配的价格&库存,您可以联系我们找货
