3412.3
3412.3
    CONTA-CLIP
    END PLATE
3412.3 数据手册
Data sheet 3412.3 FAP 2,5/4A OG End plate, Width: 1.5 mm, Colour: Orange Business data Article number 3412.3 Article name FAP 2,5/4A OG GTIN (EAN) 4044211110475 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 3.2 g Weight per piece (including packaging) 3.3 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3412.2 Product description End plate Creation date 17.12.2023 08:39:11 Subject to technical changes 1 Data sheet 3412.3 FAP 2,5/4A OG Technical data Dimensions Length 77.7 mm Width 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Candidate Substance Note Creation date 17.12.2023 08:39:11 No Subject to technical changes 2 Data sheet 3412.3 FAP 2,5/4A OG Media Creation date 17.12.2023 08:39:11 Subject to technical changes 3 Data sheet 3412.3 FAP 2,5/4A OG Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3215.2 FSL 2,5/4A GNYE 4044211110154 100 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 2.5 mm², Width: 5.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3212.2 FRK 2,5/4A BG 4044211109868 100 Creation date 17.12.2023 08:39:11 Subject to technical changes 4
3412.3 价格&库存
很抱歉,暂时无法提供与“3412.3”相匹配的价格&库存,您可以联系我们找货
    • 20+10.9750520+1.42147
