3421.1
3421.1
    CONTA-CLIP
    END PLATE
3421.1 数据手册
Data sheet 3421.1 FAP 4/3A GN End plate, Width: 1.5 mm, Colour: Green Business data Article number 3421.1 Article name FAP 4/3A GN GTIN (EAN) 4044211110512 Packaging unit 20 Quantity unit PC Weight per piece (not including packaging) 2.65 g Weight per piece (including packaging) 2.67 g Unit of weight G Customs number 85389099 Country of origin DE Prio-Article 3421.2 Product description End plate Creation date 17.12.2023 08:39:20 Subject to technical changes 1 Data sheet 3421.1 FAP 4/3A GN Technical data Dimensions Length 64.3 mm Width 1.5 mm Height 31.5 mm Materials Material Polyamide 6.6 Flammability class UL 94 V-2 Working temperature, min. -40 °C Working temperature, max. 105 °C Environmental Product Compliance REACH Conform Yes REACH Candidate Substance Note No Creation date 17.12.2023 08:39:20 Subject to technical changes 2 Data sheet 3421.1 FAP 4/3A GN Media Creation date 17.12.2023 08:39:20 Subject to technical changes 3 Data sheet 3421.1 FAP 4/3A GN Accessories ##INVERSE##CONTA-CONNECT Protective earth terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Green-yellow Article number Article name GTIN (EAN) Packaging unit 3224.2 FSL 4/3A GNYE 4044211110178 100 ST Feed-through terminal, Push-in connection, Mounting type: Mounting rail TS 35/7.5, Rated cross-section: 4 mm², Width: 6.1 mm, Colour: Beige Article number Article name GTIN (EAN) Packaging unit 3221.2 FRK 4/3A BG 4044211109981 100 Creation date 17.12.2023 08:39:20 Subject to technical changes 4
3421.1 价格&库存
很抱歉,暂时无法提供与“3421.1”相匹配的价格&库存,您可以联系我们找货
    • 20+10.9750520+1.42147
